February 11, 2025, 12:07:35 AM *
Pages: 1 2 [3] 4   Go Down
Author Topic: Front Brake problems  (Read 6935 times)
loony888
"I WAS GOING HOW FAST, OFFICER?"
« Reply #30 on: April 11, 2010, 08:48:53 PM »
love to see dribbles of information when you're trying to help someone, for make the beast with two backss sake vince! tell us you have changed levers and pads and they're useed, and you didn't mark what place they were in on the other bike and it was doing it before you changed the pads over etc. etc.
are those fancy levers set correctly, the old type with the screw in the end were notorious for blocking the bypass port in the m/cyl when wound in too far causing a build up in pressure and locked brakes. yeah yeah, i know, you know what you're doing and it can't be that but your brake fluid theory is bogus. there's no way brake fluid will expand when it gets hot, it's designed to do exactly the opposite and being a serious safety item (brakes!) it just wouldn't be acceptable to allow that under any circumstances.
paul.
                                              93 888 RS
                                              09 1098R BAYLISS
                                              07 Husqvarna TE 450
                                              01 S4         93 900M
                                              96 748SP
DUCMONROB
Geez its getting hot holding my
Nothing like the sound of a Ducati!
« Reply #31 on: April 11, 2010, 09:36:03 PM »
paul.
+1 waytogo
M1000SDS, ZZR1200, GPZ900R.
Gone:
900 Monster Special
S2R1000
998 Matrix
Dockstrada
« Reply #32 on: April 11, 2010, 10:45:40 PM »
Ok some more information dribble.
After the calipers cool down, Hey presto it all comes good. How do you explain that, i have no idea other than the expanding and contracting of something  Huh?
spoke to somdumguy today he say "danielson"  in some cases there is small air bubbles trapped in the calipers in areas higher that the bleeder or brake line connection,which can cause this problem.
The most common way of getting air into your system is pushing the pistons back to fast , this mixes small air bubbles in with the fluid as it returns to the reservoir ,When you pump your leaver to take up the slack after fitting new pads you send it back down the line with the fluid.  Huh?
If I wasn't who i was, I wouldn't be who I am !
loony888
« Reply #33 on: April 11, 2010, 10:50:14 PM »
well bleed your brakes properly then!
                                              93 888 RS
                                              09 1098R BAYLISS
                                              07 Husqvarna TE 450
                                              01 S4         93 900M
                                              96 748SP
Dockstrada
« Reply #34 on: April 11, 2010, 11:03:00 PM »
Going to try some Motul 660 factory line .
loony888
« Reply #35 on: April 11, 2010, 11:09:28 PM »
what's the DOT rating of that?
the higher the dot the faster it absorbs moisture and the more often you will need t replace it. waytogo
paul.
                                              93 888 RS
                                              09 1098R BAYLISS
                                              07 Husqvarna TE 450
                                              01 S4         93 900M
                                              96 748SP
Dockstrada
« Reply #36 on: April 11, 2010, 11:14:18 PM »
paul.
Im going for DOT4
RBF660 FACTORY LINE
100% Synthetic Racing Fluid – DOT4
Very high boiling point: 325℃/617°F
Very high wet boiling point: 204℃/400°F.
SPECIFICATIONS
Feature 100% Synthetic Racing Fluid. Polyglycol bases.
SAE/DOT Standard FMVSS 116 DOT 4/ SAE J1703 & J1704
Specification ISO 4925
http://www.motul.com.au/product_line_up/fork_brake_others/others03.html
Nickati
Yippee
« Reply #37 on: April 12, 2010, 12:16:57 AM »
I still can't see it being the issue
Hey why you want brakes anyway, they just get in the way of speed  Evil
Life's TOO short to go slow !
brad black
« Reply #38 on: April 12, 2010, 12:57:45 AM »
after a session put a piece of clear hose on a bleeder, hold it vertically and crack the bleeder.  fluid comes out quickly = fluid pressurisation problem.  it will run fluid out slowly due to the level difference, but if it shoots up the tube it's pressurising.  close the bleeder and try moving the bike too.  make sure nothing is blocking the piston from coming as far as as it would without a lever fitted.  the only way it can pressurise if is the compensating port is blocked.
Brad The Bike Boy
http://www.bikeboy.org
Nickati
Yippee
« Reply #39 on: April 12, 2010, 01:46:22 AM »
One question, did just changing the pads fix the original problem ?
loony888
« Reply #40 on: April 12, 2010, 10:22:48 PM »
top advice, i suspected the levers not being set right as the culprit when vince posted the pic of them, excellent way to diagnose it brad.
paul.
                                              93 888 RS
                                              09 1098R BAYLISS
                                              07 Husqvarna TE 450
                                              01 S4         93 900M
                                              96 748SP
Nickati
Yippee
« Reply #41 on: April 13, 2010, 12:14:44 AM »
Or was something else done at the same time ?
Or did all this start after the levers were fitted ?
Dockstrada
« Reply #42 on: April 13, 2010, 12:46:16 AM »
Started with in a few track days and got worse still as a standard bike.Its only when i fitted the last set of pads that it is so bad that the front wheel need a fair amount of force to get it to turn.basically i need one hand to turn the wheel to fit the tire warmers.But as stated before after a short while it all sorta goes to back normal, just a little drag.
Some extra dribble, cuz i know how much Loony hates it.
The rotors are blue/black not on the ends just on the faces.I have also noticed that some of the racer guys have the same problem ,just a little less than mine.waiting for Craig McMartin to give me a buzz with some info.
BR Vince
Dockstrada
« Reply #43 on: April 13, 2010, 01:02:30 AM »
Just found this. waytogo
http://174.143.221.140/ME2/Audiences/dirmod.asp?sid=&nm=&type=news&mod=News&mid=9A02E3B96F2A415ABC72CB5F516B4C10&tier=3&nid=7A529F8E7D7748A992DC1F09C716CA00&AudID=7D8998E6B4B64029B8320B216F4F3861
signora monster
« Reply #44 on: April 13, 2010, 01:52:33 AM »
My old Kawasaki is a bit like this. Could it be wheel bearings?  Huh?
Kaz.
Pages: 1 2 [3] 4   Go Up
