Trailer Brake Controller
Started by Punx Clever, April 11, 2010, 05:19:32 PM
Punx Clever
Picking up a new trailer for the duc tomorrow... need advice on a brake controller.
Truck is a 2006 GMC sierra half ton with the towing package.  Already have all the wiring in place for a brake controller.  Just need the unit itself.
Trailer is a Pace American Outback 7x14 cargo trailer with dual axles.  Max GVR is about 7000#
So, advice? Suggestions? Previous experience?  I don't suspect the higher end models will brake the bank (about $150 or so right?), so the full range is fair game.
2008 S2R 1000 - Archangel
muskrat
I honestly don't  think you'll need one for the Duc.  I towed a 3,000 lbs trailer with my Z71 with two full dressers with no stopping issues - if you plan ahead.  :)
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
Punx Clever
Duc's home will at some point be a mobile shop with tool chests and work bench. meanwhile, it will be used to move the rest of my stuff (see: junk) whenever a new set of orders pops up.
hcomp
I've used an off the shelf U-haul brake controller for towing roughly the same trailer specs but add a car (not bike). It has worked perfect for years.
にã,,かかã,ã,‰ãšã€ç§ã®è»Šã¯æœ¬å½"に速ã,,ドラã,¤ãƒ–、私は女性のç"Ÿæ®–器のã,ˆã†ãªãƒã,¤ã,¯ã«ä¹—ã,‹
Qfactor
muskrat
each bike weighed in at over 800 lbs plus trailer.  unless you're doing a lot of "hill" driving I've rarely had a need to use them under 5,000 lbs.  BUT it's cheap insurance and I too have had good luck with the Uhaul version.
2015 MTS 1200
09 Electra Glide
Punx Clever
JEFF_H
i got one that is electronic so it doesnt have to be manually calibrated.
i was always messing with the old one not knowing what setting to use.
