February 06, 2025, 03:44:32 AM
MAP on PC3 for s4R 2005 w zard full exhaust
Topic: MAP on PC3 for s4R 2005 w zard full exhaust (Read 1076 times)
Mikkel67
April 16, 2010, 11:06:39 AM »
Hi,
does anyone her know which map i should use on MAP on PC3 for s4R 2005 w zard full exhaust?
Duckintime
Re: MAP on PC3 for s4R 2005 w zard full exhaust
April 17, 2010, 03:03:19 PM »
each bike is different,even though it maybe the same model.. you WILL need to get a dyno'ed map for your bike. Dont bother with downloading the maps from PC.. they dont work.
Mikkel67
April 18, 2010, 08:23:06 AM »
okay,
that is not good news. I don`t think there is anybody selleing, hence tuning the PC3 in Oslo.. Any other way?
April 18, 2010, 09:09:16 AM »
I'd try the M710-004 (S4R Model, Arrow full exhaust and K&N air filter) from here:
http://www.powercommander.com/powercommander/powercommander_iii_usb.aspx?mk=5&mdl=23&yr=2005
Certainly not as good as a dyno map, but should be a decent start.
Mikkel67
April 18, 2010, 09:25:09 AM »
thanks,
that is the one i use now. I tried another one, and i was terrible. The one you suggest works well, but not perfectly. Still some backfire and not perfectly smooth running at around 4000 rpm.
Any other good maps?
April 18, 2010, 09:28:16 AM »
I don't know of another map.
Doesn't mean there isn't one out there...
Modify the map yourself?
Mikkel67
April 18, 2010, 09:36:09 AM »
I don`t think i have ths skills to do that. Do i need to reset the trottle position every time i try a new map?
S2R 800 '07
April 18, 2010, 09:59:10 AM »
Hi Mikkel
Hestmann Motor in Oslo is listed as a service center. Don't know what they do, but worth a call?
[moto]
Duckintime
April 18, 2010, 10:16:20 AM »
Quote from: Mikkel67 on April 18, 2010, 09:36:09 AM
No you dont need to. The problem with the PC website, is the map profile is all over the place. A proper map from what I was told should be straight horizontal lines to provide a consistant CO, HC reading out the tail pipe.
Last Edit: April 18, 2010, 02:47:40 PM by Duckintime
Jumptship
April 18, 2010, 12:32:22 PM »
Just got mine done @ Ducshop. One of the things mentioned is that no matter how good of a map you have if your cams aren't degreed it won't make a difference. Bite the bullet, take it in and get cams degreed and a custom map...you won't be sorry!
This has been a test of the Emergency Broadcast System.
