Boat trailer hub bearing tech question
Started by mitt, April 19, 2010, 04:15:49 PM
Stinky Wizzleteats
Angle grinder & a cold chisel.
You don't need to go the whole way through, halfway is good enough, then lay into it with a cold chisel.
It should pop right off.
I like a drink. You know when people say 'I like a drink as much as the next man'? Not if I'm the next man, you don't.
VisceralReaction
I used a carbide attachment for my dremel when I did it once and cut little nicks around above the race so
I could get a bite on the race with a punch. Worked good. didn't take much.
Quote from: VisceralReaction on April 20, 2010, 07:17:19 AM
That was the exact idea I was leaning toward trying tonight.
thanks for all the feedback!
Well, a nice sharp hardened punch did the trick the normal way. It was able to get a bite.  I was surprised how well it did compared to a "sharp" screw driver.
Stinky Wizzleteats
You know to get a similar effect with a screwdriver that you get with a punch would be to get one with the tang through the handle.  ;)
Quote from: Wood Duck on April 20, 2010, 02:54:54 PM
It wasn't the blow that was different, it was the bite.  I think the punch had such a flat and sharp face on it, that it didn't "roll off" the race edge.
