Boat trailer hub bearing tech question
Started by mitt, April 19, 2010, 04:15:49 PM
OK fellow gear heads...
I am replacing bearings, seals, races.  I got the hubs off, apart, and 1/2 of the races knocked out.  The inner races are being *&^@#.  It is like there is not enough of a diameter difference between the hub and the race for me to get any bite on the race to knock it out.  I even bought a couple longer skinny flat screw drivers to get a better angle on the race, and still they just slip off when I strike it.
Any ideas?
No notch in the hub for driving out the races?
Quote from: ducpainter on April 19, 2010, 04:16:38 PM
Not that I see.  Do they usually have a notch to get things started?
Quote from: mitt on April 19, 2010, 04:18:09 PM
Not sure about trailer hubs, but automotive hubs do.
Quote from: ducpainter on April 19, 2010, 04:27:10 PM
I just looked again, and for sure, there is no groove.
It has been a while since I have worked on hubs - does heating them up with a torch ever get the race loose enough to come out easy?
If I am putting new races in, is there any "destructive" way to get them out - dremel, etc?  I have seen welding a bead on them to shrink the diameter, but I don't want to get that crazy yet.
Quote from: mitt on April 19, 2010, 04:30:44 PM
I suppose if you can get the hub hot enough without heating the race they'd come out.
It's worth a try.
Also I suppose if you could cut a slot in the race...even if you 'nicked' the hub it wouldn't make much of a difference.
Dremel with a rotary carbide cutter maybe?
gage
your hubs are more than likely not designed to be rebuilt. You can get replacement hubs with bearing seals etc for under $50 bucks each
I like this site
http://shop.easternmarine.com/index.cfm?fuseaction=catalog.catalog&categoryID=187
sno_duc
Got access to an arc welder. If so lay a hot bead all the way around the bearing race. When everthing cools down it'll fall out.
You're going to throw the old race away, so a bead of weld won't hurt a thing. Ever laid a bead across a flat plate, when it cools, not flat any more. Same thing.
A conclusion is the place you got tired of thinking
Quote from: gage on April 19, 2010, 05:11:34 PM
That could be, but what a waste of parts. I am 80% of the way to finishing them if I can get these inner races out and buy a $20 rebuild kit with bearings, races, and seals.
If you buy a pre-greased assembly, then what grease do you use to top it off?  I thought one recommendation was not to mix greases.
Quote from: sno_duc on April 19, 2010, 05:21:32 PM
I don't have a welder, but maybe I could get someone at work to do it.  I had read that method, and it sounds promising.
I am going to work on them a little more tomorrow with a fresh start and some sharper punches and see what happens.
gage
Quote from: mitt on April 19, 2010, 05:22:25 PM
Any good grease and you'll be fine
I also lied about the price - they are 36 bucks... I gladly spend the extra 16 bucks to save all that hassle and the good chance of having to buy the complete assembly anyways
sno_duc
Quote from: mitt on April 19, 2010, 05:23:44 PM
I've used it, it works well [thumbsup]. The other welder trick is to weld a hunk of scrap across the bore of the bearing race, then you can put a large punch against it and beat the puppy out.  ;D
GAAN
are the inner races F'ed up?
if not just use em
Quote from: Mother on April 19, 2010, 08:53:21 PM
if not just use em
The bearing kit will come with new races, so I would rather get the old ones out.
I've heard of the weld bead trick, luckily never had to use it.
