DP rearsets brake light?
Started by greenmonster, April 28, 2010, 02:50:03 PM
greenmonster
M900  -97, bought second hand DP rear sets, all is OK, just one Q:
There is one piece w 2 electric connections in one end & something that looks like a banjo
brake fluid line at the other end.
1. How do you fix a rear brake light function w this?
2. Original brake light thingy doesn`t work, right?
All help welcome! ;)
M900 -97
MTS 1100s  -07
If they are the same flavor as the Motowheel, AG Hammer etc rearsets then no, the stock clicker switch has not place to mount. Hence that pressure switch you've got. It's a banjo fitting as you said, that's got a pressure switch in it. I just installed one for a similar set of rear sears. I didn't want to hack my bikes harness, so I fit the pressure switch with the proper connector. You can get one here:
http://www.touratech-usa.com/shop/show.lasso?sku=015-0080&-session=touratech:CFBCDBDE076ca0F6A0HJG2AA306E
They say you can crimp the pins on... but trust me - SOLDER THEM. It'll save you a lot of the swearing I did.
Once other catch you may encounter is the stock brake line might be a bit over long. I got a custom line from HEL usa - but spiegler could do you up too. Just note that the banjo fitting that connects to the caliper is not a 90 degree it's more like 75-80 degrees/
greenmonster
M900 -97
MTS 1100s  -07
No problem. There's another thread that has a good photo of someones route for the stock line on that sort of rear set. Didn't quite work for me, but might for you.
http://ducatimonsterforum.org/index.php?topic=37739.0
greenmonster
#4
Perfect, think that will work f me!  [thumbsup]
Two spacers f the caliper & I think I`m good.
M900 -97
MTS 1100s  -07
