05 S4r Not getting that whirring sound when ignition on
Started by Islandduc, April 29, 2010, 01:56:02 PM
Islandduc
Greeting's from Cayman peeps
Bike has sat for 3 months. Battry is in good charge. So charger says :-[
Bike cranks over, needles do their little dance across the gauges. Not getting that whirring sound that accompanies the needle dance,
Could be a hole bunch of things I dare say.  Just after some suggestions and any,any help.
Many ,many thanks in advance.
Shane
Ddan
Ducati Monster Forum at
www.ducatimonsterforum.org
Islandduc
thank you Dan.
That would be 20 amp Injection ?
Looks good, don't have meter to check. Fuel down here is cr#p. might have gummed up the pump.
Whirring sound would be the pump priming to pressure ?
Thanks Mr
Did you check your kill switch?
Different models kill the bike differently.
Some use ignition and some use...
fuel. ;)
Islandduc
Kill switch in run. Bike canks over. In off position, no cranking.
Pump not priming. Gas goes like varnish down here. Remove pump it would appear ?
Quote from: Islandduc on April 29, 2010, 03:28:34 PM
It would take quite a bit of time for gas to gum up a pump. I don't think it could happen in 3 months.
Check the connector under the tank for voltage at the red wire when you cycle the key.
Islandduc
Thanks folks,
Will try that in the morn guys when I get the right tools for the right job.
Again many thanks.
Islandduc
Vroooom Vrooooomm chatter chatter
Pump out, electrical cleaner in the pump. Tap, tap with the hammer handle. Whizzz whizz went the motor.
Back together, cycle key couple of times.
See above.
The gas is soooooooooooo bad here. Will have to clean out tank as you can see a tan line from the gas.
All good and thanks for the help.
Now to put the BST's and all that other stuff sitting in the shed
Enjoy  [thumbsup]
