Output shaft seal
Started by avizpls, April 30, 2010, 04:49:17 AM
avizpls
discalimer-I tried the search, came up with mostly clutch slave problems.
I cant remember since having my motor apart....is the output shaft seal one you can replace externally without splitting the engine?  [bacon] sweet.
Im at work now wondering about it: seems like it may be tricky to remove with the output shaft still there
1994 M900 btw
#11
It can be done.
It's the hard way to do it, providing you've got the engine split already.
avizpls
I dont have it split. I didnt realize this seal needed replaced until after I reassembled.
How do you get the seal out? with the motor on the bike still?
#11
Is that seal leaking?
If it's not, then just ride it.  [moto]
avizpls
well....yeah. Its leaking a bit. nothing huge to where its unridable, but it needs replaced
#11
