clear coating dull cf
Started by hatewinter, May 01, 2010, 05:12:54 AM
hatewinter
What's the deal on putting a fresh clear coat on carbon fiber that's getting dull?
mojo
The clearcoat gives the carbon fiber UV protection to keep it from fading.  If the resin over the carbon is dull, the clearcoat will make it look like new again (and also bring out the flaws in the resin, like pinholes).  If the carbon is starting to turn yellow, it will likely look like shiny yellow/brown carbon fiber if you clear over it.
Some people are like slinky's.  They serve absolutely no purpose, but they always bring a smile to your face when you push them down the stairs.
64duc
  the only one I've found that wont turn white is polyurethane. It only lasts 6 months, then you get to do it over again. But it does work.
94 M900, 64 Diana 250
muskrat
Looks awesome once done.  Do it
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
erkishhorde
Dull or damaged? You should remove the old stuff before putting on new stuff.
http://ducatimonsterforum.org/index.php?topic=23833.0
