M696 oil cooler question
Started by DucatiSTi, May 02, 2010, 04:44:59 PM
DucatiSTi
The following pic shows the hose guides on the DP 696/1100 oil cooler
Question is: How do you secure the hose guides to the vent cover?
Right now, the guides are in the mounting hole but they are loose.
I noticed that there is a pin that possibly expands the stud on the guide into the hole on the vent cover
Anybody?
2009 696 Monster - Arrow Carbon slip-ons, Bitubo steering damper, DP oil cooler, DP Touring Seat, Rizoma tail chop, Rizoma Zero 11's, Stebel Nautilus horn, Ducati Euro shroud, Speedymoto sliders (axles and frame)
DucatiSTi
I went to the dealer and looked at a M1100
The pin inside the hose guide was pushed in which mushrooms the stud into the mounting hole
Went home and pressed the pin in with a small c-clamp - worked like a charm
Now the hose guides don't move around
Not bad when you use the round thing attached to your neck ;D
BTW, hope this helps someone else
is that the dp cooler? it doesnt' come with stainless lines?
DucatiSTi
yep its the dp cooler
the hose you see is from the canister
 [laugh] Even Ducati understand that the canister will be taken off. Why bother fastening the hose guides [thumbsup]
