Access DB question
Started by Monster Dave, May 04, 2010, 07:00:15 AM
Monster Dave
Hey guys,
I'm having a bit of a brain fart and need some help with a database question:
I'm using Access 2007 and I have a table with Patient ID's that share relationships with other tables. I need to be able to offer the user the ability to change the Patient ID from within a form.
Any ideas what the easiest way to do that would be?
Thanks!
cyrus buelton
I'd need your Access File to see how the tables are set up before I can troubleshoot the easiest way to do this.
However, since you said "patient" I figure this must be medically related and you can't send it to me because of HIPPA Laws.
1999 M750 (joint ownership)
2004 S4r (mineeee)
cyrus buelton
You should just be able to change in the initial input form.......
Is that field locked or a auto-number?
2004 S4r (mineeee)
ryandalling
You also need to worry about linked tables using the patient number as a key. If you update the number, then the linked data in other tables would not link due to mismatch in the key.
Confused rider who doesn't know what he is even riding at the moment. (2012 URAL GearUp, 2012 Ninja 250 Racer, 1969 CB175 Racer)
Monster Dave
This is where I'm having the brain fart today.
I have a form for adding a new patient - that data includes a PTID and a screening date along with various ethnic information data.
Once that data is entered it goes (obviously) into a table that drives all info related via other tables (1-to-1 cascading). I need to offer an "Edit PTID" from a form but (here's the brain fart), how can I have a user edit the PTID without doing it from within the table itself?
Monster Dave
#5
Quote from: ryandalling on May 04, 2010, 07:35:56 AM
Since the data cascades would that still mean that the link would mismatch?
Crap - some days this comes so easy, others (like today) I'm struggling with retarded issue.
**Edit - so I tested changing the PTID in the source table directly and the ID change did cascade down through all the linked tables.  [thumbsup]
Scratch that part off at least as an issue.
cyrus buelton
If you have one main table that drives all your sub-tables / forms, then yeah, you'd only be able to change it in the table at the top of the hierarchy.
2004 S4r (mineeee)
Monster Dave
Right, that's what I want to do but not from within the table - from within a form.
(tough day today for MD)
[bang]
cyrus buelton
I am not sure that is possible.......
2004 S4r (mineeee)
Monster Dave
If there's one thing that I've learned about building databases, it not "if" it can be done but "how".
How about 2 separate IDs - one is your key between tables, one is the externally viewed one that can be modified?
cyrus buelton
Quote from: somegirl on May 04, 2010, 05:44:47 PM
That's a pretty good idea.........
2004 S4r (mineeee)
Monster Dave
That's not a bad idea - however, the slew of tables already in relationships are working from the PTID as the key. So adding a second ID would only muck things up.
I'm still working on it and having a better day today as far as conceptualizing the form.
cyrus buelton
Access is probably one of the worst programs ever designed.
It is confusing and just plain sucks.
2004 S4r (mineeee)
Monster Dave
Quote from: cyrus buelton on May 05, 2010, 06:36:03 AM
I wouldn't go that far. I actually really like it and have seen some amazing work done with it. You just have to be a little "creative" sometimes!
