Oil
Started by gearhead, June 02, 2008, 06:42:38 PM
gearhead
 I'm approaching the 600 mile service on my 696 and was wondering what type of oil to run. The salesman suggested full synthetic but I,ve never used it before for breaking in a bike.
mxwinky
The old-school belief has always been that full synthetic works too well and won't allow an engine to break in properly.  That idea seems to be fading away now.  There are many manufacturers that equip their brand-new bikes with full synthetic oil right from the factory and/or recommend them right off the sales floor.  In fact Harley Davidson puts a sticker right on the engine of their Screamin' Eagle models that says they're equipped with the Screamin' Eagle synthetic oil right from the factory and specify that this oil must be used in these engines.  It may have been true at one time, but today's oils are so well engineered that I doubt a proper motorcycle-specific synthetic oil would be a problem at all during break-in.  But if you're concerned at all, it doesn't hurt one bit to run regular non-synthetic until your first major service or oil change and then switch over to synthetic, if you so desire.  The main thing with oil and motorcycles is to change it regularly and use only motorcycle-specific oil, especially where wet clutches are concerned.
dlearl476
Quote from: mxwinky on June 02, 2008, 08:29:48 PM
I think it also has some bearing (no pun intended) that many manufacuturers pre-run their engines as well, for warranty's sake.  I know that all the Rotax engines we get have a bit of oil in them, and black plugs.
Motul 300V.  IMO.
gearhead
 Thanks guys....
Quote from: dlearl476 on June 02, 2008, 08:39:58 PM
Motul 300V.  IMO.
ducati pre-runs every bike after assembly.
i have video.
64duc
#5
Someday when you have 3 or 4 hours with nothing to do, read this thread. You will then learn more about oil than you ever wanted to know.
http://www.ducatimonster.org/forums/tech/122020-motor-oil.html
I have and as a result run Mobile 1 MX4T.
94 M900, 64 Diana 250
CDawg
uclabiker06
Yeah don't worry a bit about putting synthetic oil in there cuz that is what your supposed to do.  On a side not from my understanding the bikes come from the factory with a synthetic blend.
2006 S2R
2009 Smart
oldjackbob
IMO, your engine is not broken in yet...you only have 600 miles on it, and you have (supposedly) kept the rpm below 6000...that level of operation so far will not break an engine in.
Connecting rods stretch at high rpm, and the pistons (and rings) visit areas up high in the cylinder that they don't reach at lesser rpm. That's one reason I have a problem with the rule of "max 6000 rpm for the first 600 miles". But I digress...
My point is, your engine is not yet broken in. I would use a top quality non-synthetic from now until the 6,000 mile mark, changing it (and the filter) once at 3,300 miles.
After 6,000 miles, run synthetic...you're broken in by then.   [moto]
Just my $.02.
"You can't build a reputation on something you haven't done." -- H. Ford
Duc Fever
Quote from: 64duc on June 05, 2008, 07:48:38 AM
+1 on that [thumbsup]  My bike also runs a little cooler with the full syn. (MX4T)
"You have not converted a man because you have silenced him" ~ John Morely
Grappa
I was looking for the Mobil 1 MX4T and found out that the name has been changed to Mobil 1 Racing 4T.  Same stuff, different name.  Think they changed the name because outside of U.S. it is known as Racing 4T.
Ahh... but the servant waits, while the master baits.
Sometimes Aloha means Goodbye.
scduc
I just did my 600 mile oil change and used Hondas HP4. Cuz I happened to be at there shop when I thought of it. Anyhow, I believe that my S2R 1K was delivered to me with full synthetic. I also believe that if you use a well respected quality of oil, you will not have any problems. My question is with changing oils (manufactures) not grades. I like to get as much of the old stuff out as possible. I will most likely be changing to Mobil 1 at my 3000.
scduc
Oh yeah,  the only thing that will hurt if you change you oil too often is your pocket-book.
dlearl476
Quote from: gearhead on June 02, 2008, 06:42:38 PM
RTFM
