February 06, 2025, 10:27:53 AM
Project : custom bars.. - Pics - 6/21
Topic: Project : custom bars.. - Pics - 6/21 (Read 6176 times)
TAftonomos
is without a monster :(
May 07, 2010, 11:25:04 AM »
Since I've always wanted to make a set of bars, and off the shelf ones won't fit my setup, I've ordered material.
7/8" .120 wall (either that or .053...too thin) was bought for the outers, and 1.125 .083 I found for the inner section. Plan is to make a bar similar to the suburban machinery one, but route it a bit further and then back, to clear the forks that are longer/protruding above the triple. If all goes to plan, it ought to be more comfortable. Eventually I'd like to hide some pushbutton switches or switchlets (come on Mark!) on there and run the wires inside the bars.
The oberion bar end signal wires will be routed inside the bar, down through the bar clamps, and out under the triple. I've yet to decide if I want to keep the stock bar clamps, or make up some stands out of tube as well. Might look to chopperish?
Material is here, pics to follow!
Last Edit: June 20, 2010, 05:09:31 PM by TAftonomos
MyDucParts.com
pennyrobber
Re: Project : custom bars..
May 07, 2010, 12:48:10 PM »
Sounds like a good plan. I wouldn't really worry about the risers looking chopperish if they were short enough. Could stock risers be drilled out to accommodate wiring?
Mr Earl
2003 M800 Dark
May 07, 2010, 12:59:00 PM »
How far do the forks protrude above the triple? I was going to go the custom bars route to clear the 900SS forks I installed, but after doing some dowel rod mock-ups of a couple of bar designs, it became clear that they would indeed look chopperish if they cleared the fork tubes with enough room to adjust the forks. Went with clip-ons above the triple and am very happy with the setup.
Leo Vince CF slip-ons, '01 SS900 fully adjustable Showa forks w/ST2 springs, rebuilt S4 shock w/Ohlins spring, 748 dog bone, Swatt clip-ons above the triple, Sargent seat, Duplicolor-Dark seat cowl, Rizoma grips, Techlusion TFI, SBK front fender, Evoluzione slave, BMC sport air filter, 14-tooth sprocket, Desmotimes caseguard, S2R side panels, Pantah belt covers, fake CRG LS mirrors, extra black zip-ties, right grip control imprint on tank, de-cannistered, Ducati Meccanica Bologna key ring
TAftonomos
May 07, 2010, 02:40:45 PM »
I can drill the stock risers and use those....and may end up doing just that
The forks arn't up enough to fit triples above, and the upper triple is too beefy to fit a triple with a rise. And driving around in a SBK position is out for my daily bike (thats why they make SBK's).
The suburban bar just doesn't go forward at a sharp enough angle to clear. I have 2 choices...but higher risers and a suburban bar, or make something that will work with what I've got.
Oh....and the place I ordered the tube from sent me 1 and 1/4", which isn't going to work. So this is postponed until I get the correct material. Anyone have any 1.125 in .083 wall or thicker?
MyDucParts.com
TAftonomos
Re: Project : custom bars.. - updated 6/11
June 11, 2010, 03:48:38 PM »
Got back from my biz trip, wife took kids and left for the weekend for reunion etc...= fun time for me
It's a start:
Stock bars, dirty table
Nothin' fancy, just a saw
Use this to stick it together
Precision angle finder:
Pretty close
Halfway check
Another:
Now you see why I needed to make them:
I call it "el toro"
The bull
Horns
Mockups:
Going to get the hole saw tomorrow. I'll saw through the end/cope it, and tack the bars in. Hopefully this wasn't all for a waste. Then (obviously) finish welding them, and send them away for powdercoat (black?) along with a few other things. About 2 hours work to this point, should have them done in under 4. I need to make the 7/8" part longer to accomidate the bar end mirrors that I have. Currently (with the oberion signals) the bars are the same width as the stockers
Last Edit: June 11, 2010, 03:51:31 PM by TAftonomos
MyDucParts.com
DucHead
No garage queens
June 11, 2010, 04:27:02 PM »
As usual, great job Theo!
They'll end up looking like the Suburban Machinery bars (which I like).
"45"
Howley
June 11, 2010, 11:34:57 PM »
Quote from: TAftonomos on June 11, 2010, 03:48:38 PM
Horns
Looks like the left bar needs to be angled slightly more to the left.
1KDS
June 12, 2010, 10:32:21 AM »
No, I think the headlight is off center to the left a hair
Every bike I've ever owned.
June 12, 2010, 10:34:28 AM »
Quote from: 1KDS on June 12, 2010, 10:32:21 AM
i think he's looking at the bars as compared to the forks. it does look off, but it could be the angle of the photo as well.
TAftonomos
June 12, 2010, 10:53:09 AM »
It's all made by hand, so it might be a smidge off here and there.
The angle doesn't look right in the photo, but the angle is the same on either side....I think it's the length (which doesn't matter) on the bar at the moment....gets trimmed when I fishmouth the ends.
MyDucParts.com
rosstermyer
M1100S
June 12, 2010, 04:11:34 PM »
badass! i like what you have going here. like someone else said they will be similar to suburbans, but better coz they will be DIY!
Howley
June 13, 2010, 02:09:40 AM »
The pic is pretty much bang on centered over and square with the triple, and I get it being about 1.4 degrees out. Don't know if you care about 1.4 degrees (sorry, I'm a surveyor!).
pitbull
June 13, 2010, 02:52:50 AM »
very, very cool. I love creative ideas like this.
TAftonomos
June 14, 2010, 02:24:13 PM »
Went and bought the correct size hole saw....got home and realized I didn't have the correct adaptor thing to use it with. It's hot, I'm unmotivated, so I didn't go back out.
I'll get it on the way home from work tomorrow, and hopefully I can light a fire under my ass so I can finish this fab work and go ride the thing.....
MyDucParts.com
billg69gmc
Reply #14 on:
June 14, 2010, 04:01:36 PM »
Theo,
I was thinking about what you said about having the ability to install buttons or switches. A while back I sent out some emails to those who make the dog bone handlebar clamp. I'm thinking that if you weld on a piece of stock to the center of the dog bone, it could hold more than enough micro switches. I think I will try this and see what it looks like. Pardon my photoshop
2010 StreetFighter S 2008 Hym1100 2006 S2R1k
