February 11, 2025, 07:48:28 AM
Please Help
Need help with Ohlins replacement spring
Topic: Need help with Ohlins replacement spring (Read 3567 times)
Tyler1150
May 08, 2010, 02:40:46 PM »
I know that this has been posted many times but i am having trouble finding an answer within old threads. I am 200lbs and My existing spring (95 M9000 is rated for a much smaller person.
Could anyone tell me which replacement spring to consider? I recall the number being something like 1092-31....
Thanks!
suzyj
Does my bum look big on this?
Re: Need help with Ohlins replacement spring
May 08, 2010, 03:56:07 PM »
I'm not 100% sure of the geometry of the M900, but the spring I'm buying to fit to my 695 is an Ohlins 01091 31/95, which has a 95kg/mm rate.
Ducati up north have a table on their website which recommends 10n/mm (98kg/mm) for a 200 lb rider on an M900. The closest spring is an Ohlins 01091 34/100, with 100kg/mm rate.
Here's the link to their tables:
http://www.ducati-upnorth.com/tech/suspensionspring.php
Bear in mind that a large change from the stock spring may necessitate revalving.
May 08, 2010, 04:59:48 PM »
Quote from: Tyler1150 on May 08, 2010, 02:40:46 PM
Thanks!
I'm 180 ish and have a 10.0 ohlins spring on my bike.
I'll look for the first series of numbers if you want but I think a 10.5 would be right for you.
Charlief
May 09, 2010, 03:45:17 AM »
I would agree with dp
at the time I was 215-220 I had 11.0 on mine
May 09, 2010, 07:17:03 AM »
let me know what spring you need. I have on hand a brand new ohlins spring that ive been trying to get rid of.
I wrote down the actual rate somewhere, but id have to find it.
THe only thing is, i dont know if your spring is different from a modern monsters spring. The only thing i know is, it is bolt on replacement for the OEM springs of the older monster line up (pre 696).
weemonster
weeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
May 10, 2010, 02:42:07 AM »
what sort of weight of person is the original spring meant for?
May 10, 2010, 05:17:58 AM »
Quote from: weemonster on May 10, 2010, 02:42:07 AM
being a progressive spring. its suppose to be decent across a broad range of weights. but really, maybe 150tops.
weemonster
May 12, 2010, 02:44:02 AM »
Quote from: He Man on May 10, 2010, 05:17:58 AM
ok cool.
i'll be alrigght then. being small rocks sometimes lol
ajw85
May 12, 2010, 03:29:59 AM »
Quote from: suzyj on May 08, 2010, 03:56:07 PM
sorry to be picky, but the replacement for a monster spring is a 1092, superbikes are 1091
suzyj
May 12, 2010, 10:52:38 AM »
Quote from: ajw85 on May 12, 2010, 03:29:59 AM
No, pickiness is good. I'm putting the spring on a 749s/999 shock. I had foolishly assumed the springs for monster shocks and sbk shocks were interchangeable. Is the difference unloaded length?
May 12, 2010, 11:11:00 AM »
Quote from: suzyj on May 12, 2010, 10:52:38 AM
they are interchanable. I have 3 springs siting next to me.
one is a 999 stock spring, the other an ohlins spring that fits on a monster shock, and the other is a monster S2R spring.
the only difference is length.
