February 06, 2025, 07:11:07 AM *
Author Topic: Easy M1100 reservoir mod for people without mirrors.  (Read 1462 times)
crimsoncloak
« on: May 09, 2010, 07:04:43 AM »
After removing the stock mirrors and flyscreen for a meaner more "Monster-ish" look, I found that the stock master cylinder reservoirs stuck out in an unattractive way.
Well I just happened to have a some 999 master cylinder reservoirs laying around.  They are often removed from that bike when the bars are raised to get more fairing clearance, so there should be plenty out there.
Really easy swap, but you will need the back half of the perches without mirror bosses from a HYM or 999, and the funky adapter bolt/bleeder that holds the cup to the master.  You need the perches for clearance on the cups, and also becuase they look way better now that the mirrors are gone.  The perches are easy enough to get, but Ducati doesn't sell the bolt/bleeder adapter seperate of the master cylinder.  So if you don't have a used one available you can't get it from Ducati.  Jen @ DucatiOmaha was able to get me a set from a Brembo importer.  Probably Yoyodyne.
The only other thing you'll need to do is flip the throttle assembly 90 degrees and drill a new locating hole for it, as the 999 had the throttle cable exiting the bottom of the housing.  It doesn't affect function or looks to any great degree.  Be precise with your drilling, because there is a narrow window for the cable to pass through on the bottom of the master cylinder.  It is also important that you have your levers angled the way you like them when you choose the location of the throttle assembly, because when you are done there will be very little room to change the position after.
Anyway, here are a couple pics.
Uploaded with ImageShack.us
« Last Edit: May 10, 2010, 10:53:29 AM by crimsoncloak » Logged
causeofkaos
« Reply #1 on: May 10, 2010, 08:29:14 AM »
DUDE! that looks clean!
Favorite convo i read on this board
"PICS OR IT DIDNT HAPPEN"
"F**K U IT HAPPENED"
Suzuki Blvd M109R " Sliver " = assassinated by cager
PW 696 " Pearl " = traded in
M1100 " Loki " = Viking God of mischief ( Goddess in this case )
Life is not a journey to the grave with the intention of arriving in a pretty pristine body, but rather to come in sliding sideways all used up screaming F*CK YEAH WHAT A RDIE!!
R0CKETMAN
« Reply #2 on: May 11, 2010, 02:09:36 AM »
Looks clean, makes your turns look like big ears sticking out though. I see new blinkies in your future.
crimsoncloak
« Reply #3 on: May 11, 2010, 04:34:27 AM »
Yup, it all flows down hill....
Mirrors deleted = made flyscreen look goofy
Flyscreen deleted = made reservoirs look too tall
Reservoirs docked = made turn signals look too big
I'm thinking just shortening the stock turn signals will look pretty good, but I may put some little black R&G signals on there if I feel like the stock ones are still too big.
causeofkaos
« Reply #4 on: May 11, 2010, 08:23:15 AM »
there are spacers on the front signals you can easily remove those however you will need shorter bolts. i did mine and it helped a lot on mine i think, the stock ones are way too long no matter what.
R0CKETMAN
« Reply #5 on: May 11, 2010, 11:07:08 AM »
Zero 11's resemble the shape of the res. Would look sweet. I like the looks of mine on my 1100.
