Greasing electrical connectors
Started by Fruity, May 10, 2010, 02:47:24 PM
Fruity
guys, how many electrical connectors are there all together that need dielectric grease? are there some that are more important than others. appreciate if someone can chip in.
cheers.
Always working hard at hardly working.
battlecry
I did all but the CPU connectors, but over time as I worked on the bike and it became convenient.
Must do the stator to the rectifier.  Resistance there will lead to a meltdown.
I also think the neutral switch is a good idea.  It can get water/corrosion and the signal goes to the cpu.
The battery terminals are also a good idea.  If you cant get the Bosch battery grease, mix some baking soda into the grease.
Fruity
thanks battlecry, i've already done the neutral switch and a couple of other connectors connected to it. now to do the stator/recitifier.
cheers mate/
battlecry
It may also be a good idea to protect the fuses and the lamp contacts.  Pretty soon, as you work on the bike, you will get them all.
Grease is cheap... I keep it on hand and (try to remember to) put it on just about anything I disconnect. Cheap insurance, and it makes working on the bike easier, later on. Same idea for anti-seize on bolts where applicable.
Fruity
yup, good practice. keeps the headache in check.
thanks.
