April 29, 2024, 03:03:20 AM
THCM
Tire questions & etc.
Topic: Tire questions & etc. (Read 1992 times)
wcw
May 11, 2010, 07:07:53 AM »
Was debating about to just get replacement OEM tires or Pirelli Diablo Corsa III's. What do ya'll think? Also, is it a must to replace front/rear same time? I realize I'd have to do that if I switched to Pirelli's from the stock Bridgestones.
also, thinking of a replacement wind screen. anyone have a suggestion for one that pushes a little more air up & over? think i saw a Zero Gravity one.
last question, need a firmer rear spring for 2up riding...will take any leads for this too!
Thank you!
C
Last Edit: May 11, 2010, 07:32:11 AM by wcw
Diavel Carbon Red
hiero
Re: Tire questions & etc.
May 11, 2010, 09:47:58 AM »
no experience with the pirellis, but I always ride on the same tire front and back, I wouldn't recommend any other way
I like racetech springs and have them on both sets of front forks and on the rear of the 748. Monster has ohlins.
2000 Monster 750
1999 748
YELLOW!!
The Bearded Duc
a.k.a. duc750
May 11, 2010, 10:15:44 AM »
Don't know much about the rest but I just replaced my tires and before doing so asked a bunch of questions to a bunch of people for a bunch of information.
A lot of people use different front and rear tires from the same company. Depends on the type of riding you do most. Mine is commuting with only a few canyon days.
Using a sport touring, or dual compond rear will give the rear a longer life since most of the time the front lasts longer you will be replacing a set rather than a 2-1 ratio. However, like I said, I think the most important part is they need need to be from the same manufacturer.
I was recommended a Michellin Road 2 out back and a Pilot Power up front. The Road 2 will most likely last as long or close to the Pilot Power and therefor will have even wear in the front and back. However, some people prefer to only buy one tire at a time (cost reasons, mostly) and don't mind the rear wearing out sooner.
To answer your question, no, you don't have to buy front and rear at the same time. And the Diablo Corsa's are a really good tire.
Tires are a safety thing as well as preference so unfortunately you will most likely go through a coupe sets before you find the ones that work well for your needs.
2001 M750 - Sold
Porsche Monkey
JuddDdd likes my
The DMFer formerly known as Ducaholic
May 11, 2010, 03:57:30 PM »
Chris, I'm on my second set of bridgestone BT016s. Love em even though they only last 3000 miles before the rear needs replacement. Cyclegear has a set in stock as well as most other brands. Their prices are hard to beat too. The BT016s may be too soft if you are going to do longer rides 2 up. Corsa 3s will also be a fast wearing tire. Quite a few people are using Michelin Pilot Road 2ct with good results. Guess it all depends on how aggressive you plan on riding, within the law of course.
Jon
Quote from: bobspapa on July 18, 2009, 03:40:31 PM
The Bearded Duc
a.k.a. duc750
May 11, 2010, 04:04:31 PM »
Motorcycle-superstore.com is cheaper than Cyclegear in the tire department and they arrive at your door in 2 days!
Last Edit: May 11, 2010, 04:06:18 PM by duc750
2001 M750 - Sold
Greg
August 16, 2010, 03:08:49 PM »
Not sure if you bought tires already but I saw these guys with a very good deal.
www.ridedirect.com
has a pair of BT016's for only $185 a pair
www.motorcycle-superstore.com
wants $236 for the same pair
That's a $50 savings for a set of tires, not too shabby.
www.Cyclegear.com
wants $269 for the same set
2012 M1100 Evo with Termis
