February 06, 2025, 03:57:31 PM *
Pages: 1 2 [3]   Go Down
Author Topic: CNC Italy... Anyone order from them?  (Read 10389 times)
The Bearded Duc
a.k.a. duc750
« Reply #30 on: May 23, 2010, 09:55:25 AM »
Hey corey, got any pics of the brackets yet?
2001 M750 - Sold
silversled
« Reply #31 on: May 23, 2010, 01:33:07 PM »
...and torqued them down onto my 51mm section on my 999 forks, and they stretched just fine. .
But will they fit the 54mm section of my GSXR1000 forks?Huh?
corey
'06 Tang/Black S2R800
« Reply #32 on: May 24, 2010, 07:58:42 AM »
the 50mm ones won't, but CNC in italy does sell a 54mm version Wink so you're in luck Grin
PICS to come soon, I promise. I'm washing the bike soon, and taking a bunch of pics to show off the fork swap and everything.
Airborne
Crash n' Burn
Monster S2R 800 - ALL BLACK
« Reply #33 on: May 24, 2010, 01:06:21 PM »
I just ordered the headlight bracket eliminators in titanium. It'll be awhile before i install them but i'll post up pics when i get them.
BellissiMoto
« Reply #34 on: May 24, 2010, 05:10:34 PM »
Hey Airborne,
I was wondering if that was a forum member who ordered those... and since it was, you will be getting 10% back via partial refund in just a moment as your forum member discount.  Wink
In the future though, just send me a quick message in the payment notes or via PM so I'll know to hook you up!
Thanks and I'll send you a tracking number as they ship out.
- Randy
♣ McKraut ♣
touched by his noodly appendage
« Reply #35 on: May 25, 2010, 06:50:25 AM »
are there any pics out there of the before/after or install of the u-bracket replacement clamps (listed as "fork collars" on bellissimoto)?  i'm just trying to visualize how it works exactly to replace the u-bracket.  this can be used with stock triples, right?  i'm interested in getting rid of the U-bracket if it just costs $75, but not so much replacing the triples ($725)
-  Dallas, TX
corey
« Reply #36 on: May 25, 2010, 10:15:18 AM »
there are two rings that clamp around each fork.
in each ring, there is a recess that you stick a small spacer (included) into, and then your stock headlight ears/tabs bolt into those. then you just bolt your headlight on as normal.
the only kink i hit was what to do about the part of the u-bracket that holds the brake lines in place. on a stock setup, might not be a huge deal. but with my newly added clipons, i have a lot of extra brake line, and was in need of the hold-downs. luckily i had an extra u-bracket, so i just hacked off everything above the bottom part that bolts over the brake lines, sanded & painted, and bingo.
as stated, pics to come...
Airborne
Crash n' Burn
« Reply #37 on: May 25, 2010, 12:40:20 PM »
Hey Airborne,
thanks bacon
did you use them to lower the headlight? I'd imagine that'll work for it right? Pretty much the reason I ordered them.
corey
« Reply #38 on: May 25, 2010, 02:01:30 PM »
thanks bacon
yup. you can lower it clear down to the bottom triple clamp.
i had it bottomed out all the way down low... looked a bit silly that low... so i moved it up a bit.
be patient with the install, it's a bit of a PITA because the brackets are connected to each other in any way, so you'll have to measure and test fit stuff to get it all lined up properly... but the end result is well worth the patience.
Javi
« Reply #39 on: August 10, 2010, 10:47:15 AM »
Ordered the red ones from Bellissimoto! Pics as soon as they're installed  Cool
« Last Edit: August 10, 2010, 02:25:39 PM by Javi » Logged
suzyj
Does my bum look big on this?
« Reply #40 on: August 10, 2010, 11:16:31 AM »
Headlight brackets. Totally eliminating stupid factory u-bracket setup...
http://www.cncracing.it/it/content/collari-reggi-faro
They are 50mm... i'm **hoping** they'll fit the 51mm section on my 999 forks. If not... they'll be for sale.
-c
I don't like the look of the brake lines flapping in the breeze.
Pages: 1 2 [3]   Go Up
