fuel tank quick disconnect options?
Started by redial, May 13, 2010, 05:15:12 AM
redial
I have been trying to find options for fuel tank quick disconnect (or if not quick, at least not
fuel-spilling all over the place) But im having problems
Ive called every auto store in town for fuel petcocks and they say they dont have anything that will work!?!?
I checked summit and this is the closest looking thing.
which would be great if it fit at all. unfortunately
it looks like it would take at least one more fitting and some grinding to cut it down to size and i have a feeling
theres not enough material to get it down to
what i believe is 1/4 inch fuel line? (ducati told me monsters use 1/4" and 3/16")
anyone have any ideas to make it easier to remove the gas tank without draining it of fuel, for
modififying and cleaning the bike?
tiaa
redial
You can get quick disconnects from Motion Pro:
http://www.motionpro.com/motorcycle/tools/category/quick_disconnect_couplings/
Most Moto shops can easily get stuff from them.
redial
#2
that is absolutely perfect and exactly what i was looking for, at much cheaper than a summit
kludge. already ordered a pair!
thanks a ton!
/thread
msh441
Just my 2-cents:
Suck it up and buy the metal connectors, as pictured here:
http://www.motowheels.com/italian/myProducts.cfm?parentcategoryid=1054%7CMonster%20Engine%20%26%20Performance&productID=3492&showDetail=1&categoryID=1079|Monster%20%20Engine%20Fuel%20%26%20Air&vendoridtodisplay=0&filterFor=&collection=1202%7CDucati
They are a s*%t load more expencive... but worth the peace of mind.
Triumph recalled all those plastic connectors after a few broke/bikes burned up.  Mine was leaking (just weaping slightly) when I underwent the recall.
I've also broken the plastic-style on my Husqvarna TE250.
The link above selld the male and female separately.  $25 each sounds really-really expensive.  I seem to remember paying about $3035 for the pair from my local fastenal after determining the correct size.
Just a thought.
redial
#4
ug and i already placed the order.
100 bucks is quite a price for a pair of those but i suppose youre right,
suck it up and dont let your bike burn to the ground  [bang]
edit: ok cancelled my order for the plastics.
Searching fastenal site, if you have any suggestions on searching please let me know.
having a hard time finding what i need *searching quick connects yields gas torch line stuff
that site you linked ended up $103 for what i need for the 2 fuel lines, yikes!!!
DucHead
Do a search for omega.com
You'll find part numbers for metal quick disconnects with shut-off valves.
redial
Quote from: pompetta on May 13, 2010, 09:59:43 AM
wow i did not expect to get many responses but this thread just gets better and better.
Omega is getting me 2 sets of these plus shipping
for a total of 22 bucks. (beats the hell out of $103)
   FT-LC220-04 is the P/N i ordered, 1/4" ID with hose barb, so hopefully this does the trick. if its not the correct part i will post up once i get them.
DucHead
#7
Quote from: redial on May 13, 2010, 10:38:23 AM
In one of those threads, I posted the part numbers.
Here they are (metal with shut-off valves on both halves):
FT-LCD170-05: $24 (5/16" ID hose barb, In-line, 2.00" Length, Shutoff, Coupling body 1/4" flow);
FT-LCD220-05: $15 (5/16" ID, Hose barb, Straights, 1.85" LCD Length, Shutoff, Insert 1/4" flow).
Here's the thread: http://ducatimonsterforum.org/index.php?topic=21234.0 (look 3/4 of the way down page 1)
BTW, a good tip from Spidey (or maybe it was Speeddog):  orient the feed and return disconnects in opposite directions.  That way, you'll never mix them up.
redial
#8
Thanks a lot Pompetta
in a related story; i give myself an F minus for searching before posting  [bang]
so in reading your post it looks like i need 2x EACH of those part numbers you listed right?
i put an email in to omega requesting they adjust my order accordingly. well see what they say.
DucHead
Quote from: redial on May 13, 2010, 10:52:11 AM
Searching can save money!  ;D
Sometimes when I do a search, it comes up empty, but if I re-type the exact phrase into the search function, viola!
Just as a reliability datapoint on the plastic units...
I've had mine on for ~6 year.
~1 year semi-exposed on the right side, last 5 years hidden under the left rear of the tank.
YMMV.
Quote from: pompetta on May 13, 2010, 10:44:16 AM
~~~SNIP~~~
That was from Spidey.
As long as you've got shut-offs on both fittings, you're good to go that way.
Mine only had shutoffs on the female fitting, so those went on the lines to the tank.
I cut the lines in different areas, so it was nearly impossible to install incorrectly.
mendoje
+1 on the metal version.  The plastic and metal version are made by the same company, but the metal ones will last.  The plastic ones come OEM on several BMW's, and they eventually crack.
Jeff
2003 M800Sie / 2004 BMW R1100S / 1981 BMW R100RS (Sold) / 1977 Kawasaki KE100 (1st Bike :))
http://ducatimonsterforum.org/index.php?topic=27788.0
redial
placed the order from omega, came out to $86, more than i wanted to spend,
but i guess its worth the fire insurance :)
msh441
Quote from: pompetta on May 13, 2010, 10:44:16 AMBTW, a good tip from Spidey (or maybe it was Speeddog):  orient the feed and return disconnects in opposite directions.  That way, you'll never mix them up.
Oh, man!  That is a good tip!!!  Thanks, wherever it came from.
Oh... and it slipped my mind that the Monster has one fuel line running to each injector.  Basiclly doubles the already expensive price I had in my head when posting (ouch!).
And thatnks for the Omega links.  I might actually do this to my Monster sooner than I imagined.
Quote from: msh441 on May 18, 2010, 06:06:38 PM
Kind of.
The monster has one feed and one return like every other FI system in existence.
The line routing is somewhat dependent on the number of cylinders.
