January 30, 2025, 06:39:13 AM
Trick to removing 696 front calipers?
Topic: Trick to removing 696 front calipers? (Read 6285 times)
mstevens
Monsterless
No Monster of my own, but my wife has an '09 696
May 14, 2010, 10:26:17 AM »
I'm trying to remove the front wheel of my 696 so I can take it in to be straightened.
The service manual says to remove the front calipers, which makes sense.
The problem is that I can't figure out how to do this. There are 2 bolts per caliper. Once they're removed, the caliper is loose, but if I pull it toward the wheel it hits the inside of the wheel before it clears the rotor. I tried some gentle wiggling in various directions to see if I could get it to clear, but without success.
I don't want to damage the rotor, the pads, or the wheel, but I really want to get this wheel off. Any hints?
Casa Suzana
, vacation rental house in Cozumel, Mexico
ScottRNelson
Mr. Dual Sport Rider
Re: Trick to removing 696 front calipers?
May 14, 2010, 10:29:10 AM »
When I have to remove front calipers, I'll twist each one back and forth until it pushes the brake pads in enough to get them off. You only need about two or three millimeters of clearance to do that. The only thing touching the rotor when I do this is the brake pad, so it can't damage anything.
Christian
May 14, 2010, 10:51:52 AM »
You can also use a small screwdriver against the brake pad backing plate. Apply a little pressure and you should move the pad away from the rotor. For best results you'll probably want to do this while the caliper is still bolted on.
Spidey
Crashin' mofo
May 14, 2010, 11:45:13 AM »
I generally first use Scott's method. Just use the rotor to push back in the pistons by wiggling the caliper. Don't be gentle about it.
If that does't work I wedge the body (not the head) of a screwdriver in between the pads and use it as a lever. That presses the pistons back in and allows you to wiggle the caliper off.
You can also do what I'm doing in the pic below using the head of a screwdriver, but be careful not to gouge the pads. To be honest, I do this all the time and haven't seriously gouged a pad in a long, long time.
Just to be safe, put some duct tape or painters tape on your wheel where the caliper is likely to scrape when you wiggle it off. I never cared with my track/race bikes, but if you have a nice pretty street bike, you can use it to avoid nicks and scapes.
Last Edit: May 14, 2010, 11:48:13 AM by Spidey
ScottRNelson
May 14, 2010, 11:48:06 AM »
Quote from: Spidey on May 14, 2010, 11:45:13 AM
Gouging a brake pad is not nearly as bad as gouging a rotor. I've never worried about it. Just don't get oil or grease on the pad.
DarkStaR
May 14, 2010, 11:52:35 AM »
no 696 FHE, but
I take the pads out, then remove the calipers. Usually I just reinstall with out moving the pistons at all.
If necessary, when I need to move the pistons, I can just use my fingers to push them back in.
May 14, 2010, 12:14:03 PM »
http://ducatimonsterforum.org/index.php?topic=36773.0
some pics of how it works. its the same for all disc brakes. the piston can be moved to get more space. just use the brake disc as leverage to compress the pads and push the pistons in.
May 14, 2010, 09:33:44 PM »
why not unbolt the calipers, wrap them in a rag, but leave them there. then remove the wheel axle to shift your wheel to give you more room.
mstevens
Monsterless
May 15, 2010, 04:34:10 AM »
Quote from: Raux on May 14, 2010, 09:33:44 PM
Because I though it wouldn't work. The spatial relationships among the rotors, calipers, and wheel don't change when the wheel moves from side to side, do they? My problem is that the clearance between the rotor and the edge of the wheel doesn't seem to be enough to wiggle the rotor off.
I'll try again today after mashing the pads.
Casa Suzana
May 15, 2010, 04:43:08 AM »
yeah silly me. thought getting the fork mounts out of the way would help, but i see what you mean. when i took mine off... well there wasn't much wheel there.
May 15, 2010, 08:26:48 AM »
thats like using a drill and pair of pliers to open a twisty bottle of beer.
your not still having problems getting the caliper off are you?
mstevens
Monsterless
May 15, 2010, 01:44:11 PM »
Pressing the calipers against the rotors to push the pistorns and pads apart did the trick.
M C Wheel got the wheel straightened in an hour and everything's now back together.
Thanks, everyone.
Casa Suzana
avizpls
TECH
May 18, 2010, 02:18:45 AM »
Quote from: DarkStaR on May 14, 2010, 11:52:35 AM
no 696 FHE, but
same here. Everytime, all the time. Yesterday, in fact.
fingerpuk
August 18, 2018, 05:23:47 AM »
Hello. Sorry to resurrect an old thread but arenthe calliper bolts normal thread? Mine will not undo, they aren’t left hand thread are they? They are lefty loosy yes?
Reply #14 on:
August 18, 2018, 05:47:16 AM »
Quote from: fingerpuk on August 18, 2018, 05:23:47 AM
Yes, 696 caliper bolts are right hand (normal) thread.
