MBP Collets
Started by He Man, May 20, 2010, 10:33:28 AM
Someone is selling a set of used 7mm collets. Was thinking about getting them for my bike. I remember someone said they arent as good as they claim it to be.
Are they just straight replacements? I have to do my 18,000 service ( at 17,300 right now and have free time)
Christian
Most of the folks I've talked to have gone with the "keep it stock" and "they aren't worth the hassle" route. I personally run stock collets and plan to indefinitely.
not a trivial install. useful if hitting high rpms often.
Quote from: a m on May 20, 2010, 02:29:45 PM
do the collets require you to get all new shims? or does it not change the measurement?
mojo
I'd imagine new collets would tighten up the measurements on the closing shims.  The original collets probably wear in and flatten a bit where the shim contacts it.
I just did a valve adjustment on my bike, and 6 of the 8 collets were in pieces.  I just ordered stock replacements from Commonwealth.
Some people are like slinky's.  They serve absolutely no purpose, but they always bring a smile to your face when you push them down the stairs.
heh. im afriad mine are broken to. The closer was within the new spec @12,000. so i let them be and sanded down the openers a bit. now im at 18,000 and the bike is running like absolute crap. but theres a lot of PM work i need to do. I havent changed oil in a while, and the clutch basket is worn to shit. etc.  got a lot of work to do next week.
anyway i bought them for $50. figure even if i dont need them, they are worth the cost since i might be needing new closers anyway.
yeah, if you got a deal, might as well throw them in. On the project 900 motor I've got, one or two of the half rings were broken, and I thought "GOOD! I was going to replace you anyway!"
 [evil]
I cant wait to do my valve adjustment. the bike is running horrible right now.  :'( i almost hate riding it.
Silver King
Quote from: He Man on May 21, 2010, 05:27:55 AM
[evil]
Shhhhh!  She might hear you.  ;D
Quote from: Silver King on May 21, 2010, 08:02:42 AM
who cares shes locked up right now.
crimsoncloak
At the rpms the 2-valvers hit, they don't offer much improvement.
If you have something that spins 12~13K, they are indespensible.  I did a whole season of trackdays with my 748 last year with no adjustments needed.  That includes plenty of 11K~12K thrashing, and big cams with oversize valves.  Would be a good choice for a S4 / S4R / S4RS if you like winding it out.
(or a 2V that's tuned up pretty high with race cams...  [evil])
at $50. im not going to complain. if my half rings are broken since ive neglected them for so long, ill consider it a cheap alternative to the OEM ones. :p
