Gauge lowering question
Started by CTKurt, May 25, 2010, 02:31:19 PM
CTKurt
What is the mechanism bolted to the frame on the u bracket on the right? When I lower it what should I do with it? Zip tie it somewhere?????
http://img.photobucket.com/albums/v138/salsajayne/Headlight%20mods/mar085Small.jpg
silversled
Ambient Air Temp Sensor..
You can zip tie it to something or make a small sheetmetal bracket mounted near the area.  It's designed to read stagnant air temp but it's best to keep it out of the direct air stream if you can.
CTKurt
Thanks for your help. Lights and gauges lowered under the tripple and it looks great. Seems everything fits better also.
