Brake line routing S2R 800
Started by Airborne, May 28, 2010, 02:11:13 PM
Airborne
I'm having trouble re-figuring out the brake line routing on my s2r. I'm guessing that from the master cylinder it goes down, up and around between the engine and the swing arm, up through all the plastic clips and then back down towards the brake. Here the speedo cable splits from the brake line and the speedo cable goes between the caliper holder and banjo bolt while the brake line continues straight down?
[bang] [bang] [bang]
2007 Monster S2R, Vespa GTS 300, 2023 Triumph Tiger 900 Rally Pro, Vino 125
uclabiker06
Yeah that sounds right.  Just get it through the upper skinnier part of the swing arm; through the plastic clips  that the speedo goes through.
2006 S2R
2009 Smart
