Drove her into a ditch.
Started by scduc, May 28, 2010, 04:50:30 PM
scduc
Yesterday I decided to take the long way home and was having a great ride until I entered a large sweeping turn with loose gravel everywhere. The only clean spots were where car tire paths were. Needless to say the front end gave loose and before I new it, I was down in the ditch. I'm not sure I could have done anything different. When the tire gave, I was able to get the bike upright, but by that time my front was in the shoulder (which was even more gravel). I came to a stop on my left side with scratches every where. Clearly, we try to stay away from gravel but once in it, what do we do? My best guess is that when I left the road, I was maybe doing 15 ~ 20mph. So a few bruises and some repair to the bike. I guess here's my chance to get a custom paint job. Ill be looking for a new seat cowl as well. My guess is that it better to ride it into a ditch than to low-side and risk serious road-rash.
Sorry to hear.
You do realize if you continue to dump her in a ditch there will come a time when she leaves you....
right? ;D
scduc
Yeah, I can tell shes upset cuz, she's making funny noises. I've been told that is is probably the shifter forks. A friend seems to think I may have bent one. Some of the other board members think it might just need to be readjusted. Not sure what to think, I'd rather not take it to the shop if I can fix it on my own. If I have to split the case, then she has to go in.
WarrenJ
Desmo Demon
Quote from: scduc on May 28, 2010, 04:50:30 PM
You wrote a life-lesson of motorcycling within your post....
Ride where the tires of cars usually are, especially when anticipating gravel.
In the early spring and often when I am on roads I am not really familiar with, I tend to ride through curves where a car's tires would be, and try to keep from clipping the apex in the curve because that is the most common location for gravel to be kicked out of the shoulder and into the curve. If you are riding too fast to be able to keep that line through the curve...slow down.
IBA #32735
