Front faring mount
Started by PAUL M, May 28, 2010, 07:22:06 PM
PAUL M
Does anyone have photos or part  numbers of brackets needed to mount a faring from a S2R to a 95
model which never came with one. ???
help would be appreciated
thanks
paul
mattyvas
I don't think you'll be able to get a bikini from an S2R to mount to a 95 model.
Pre-2000 bikes had a different mounting system.
I might be wrong but I do think that is the case.
FIFO
Hi Paul
Here are the part numbers for a sie 1000 will be the same as an s2r
I will email you the parts catalouge
the fairing is on page 143.
you might see  from the parts pictures if your bike has similar fittings
CATALOGUE No:
ISSUED:
039
143
HEADLIGHT FAIRING
09 - 02 09 - 02 09 - 02 09 - 02 09 - 02
915.1.175.1A 915.1.175.1A 915.1.175.1A 915.1.175.1A 915.1.175.1A
1 0370.72.020 Gommino antivibrante Vibration damper pad Joint en caoutchouc
anti-vibration
Schwingungsdämpfergummi Junta de goma anti-vibración 2
2 779.1.195.1A Vite Screw Vis Schraube Tornillo 2
3 0000.63150 Inserto Insert Insert Einsatz Inserto 2
4 481.1.023.1AA Cupolino (ROSSO) Headlight fairing (RED) Carénage (ROUGE) Fahrtwindschutz (ROT) Cúpula (ROJA) 1
4 481.1.023.1AC Cupolino (GIALLO) Headlight fairing (YELLOW) Carénage (JAUNE) Fahrtwindschutz (GELB) Cúpula (AMARILLA) 1
4 481.1.023.1AE Cupolino (BLU) Headlight fairing (BLUE) Carénage (BLEU) Fahrtwindschutz (BLAU) Cúpula (AZUL) 1
4 481.1.023.1AG Cupolino (GRIGIO SCURO
METALLIZZATO)
Headlight fairing (METALLIC
DARK GREY)
Carénage (GRIS FONCE
METALLISE)
Fahrtwindschutz (GRAU
METALLISIERT)
Cúpula (GRIS OSCURO
METALIZADO)
4 481.1.023.1AT Cupolino (NERO) Headlight fairing (BLACK) Carénage (NOIR) Fahrtwindschutz (SCHWARZ) Cúpula (NEGRA) 1
5 487.1.023.1A Parabrezza Windshield Pare-brise Windschutzscheibe Parabrisas 1
6 0000.63161 Rosetta Washer Rosette Unterlegscheibe Arandela 2
7 779.1.088.1A Vite Screw Vis Schraube Tornillo 2
8 772.5.024.1A Vite Screw Vis Schraube Tornillo 2
9 729906FN1 Dado Nut Ecrou Mutter
