February 06, 2025, 07:01:39 AM
The tank pad blues...
Topic: The tank pad blues... (Read 2946 times)
Re: The tank pad blues...
Reply #15 on:
June 03, 2010, 01:17:55 AM »
Quote from: Grug on June 02, 2010, 05:03:50 PM
:p How would the nib file differ from just carefully sanding it down?
The cyanoacrylate is very hard. The grit paper used on a clear coat won't level sufficiently. It rides up and over the defect.
Scotzman
Now that's thinking with your
Reply #16 on:
June 03, 2010, 01:46:54 PM »
I was just reading an article of all the magical powers of vinegar and one was removing adhesives by soaking a towel in vinegar and placing on whatever overnight and should come off. What that will do to paint...beats me.
suzyj
Does my bum look big on this?
Reply #17 on:
June 04, 2010, 05:47:44 PM »
Listen to Ducpainter - don't just rub it back with anything flexible, as the superglue spots are likely harder than the clearcoat, so you'll only go through the clear.
Use a nib file - I've also been known to use a nail file occasionally for this sort of thing - they also work well as backings for wet & dry.
Once you've removed the superglue, any damage to the clearcoat can be buffed out.
Reply #18 on:
June 05, 2010, 01:05:25 PM »
If you do use a nib file you will need to sand lightly with 2000 before buffing.
