February 06, 2025, 07:04:51 AM
The tank pad blues...
Topic: The tank pad blues... (Read 2947 times)
Grug
June 01, 2010, 09:35:07 PM »
Hey guys,
After a phonecall to my local Ducati confirmed that they'd have a nice new replacement for my old, beat-up tank pad. I followed the internets advice and went at it with a hairdryer and some WD40. And just as the internets said it would, the tank pad came off, the problem is, the little bits of superglue holding it on there did not.
'That's okay' I'll just fork out the extra for Ducati's replacement, it'll cover all that unsightly glue. A short ride later and I'm told 'whoops! we don't have that style of tank pad'.
So now I'm in a spot of bother, my tank looks far worse than it did with the worn-down/torn-up tank pad, and I can't find a replacement that will cover the glue marks left by the previous one.
Here's what the tank pad I had on the bike looked like:
It was quite a wide, solid foam pad - this renders every slinky looking contemporary tank pad I've seen unusable, as they don't cover the glue marks properly.
So I'm wondering if anyone knows where I might be able to find a replacement tank pad of the same style?
Alternatively (and I suspect the most likely option) I'll have to pick up some high-density foam, cut it to the shape I need, and fix it myself.
Does anyone have any suggestions or advice? It'd be much appreciated.
Cheers,
Mark
rockaduc
Re: The tank pad blues...
June 01, 2010, 10:25:16 PM »
Try this one from Monster Parts:
http://www.monsterparts.com/pc/TANKSLAPPER3M/Protection/TANKSLAPPER3M.html
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris, you may be only seconds away from death.
ozzys4r
June 01, 2010, 10:34:02 PM »
Go to a panel beater and get some 'prepsol' Ive never seen a glue it would not remove. It wont hurt your paint. May take a while...
Bones
In spanish she calls it
'02 M620 - '00 996
June 02, 2010, 02:40:54 AM »
looks like your tank is clearcoated.
I would use some zippo lighter fluid to take off the adhesive.
I'm a loner, Dottie...a rebel...
muskrat
June 02, 2010, 03:49:01 AM »
Goo Gone which can be found at WalMart and you're all set
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
DarkStaR
June 02, 2010, 04:06:55 AM »
Quote from: Grug on June 01, 2010, 09:35:07 PM
...the problem is, the little bits of
superglue
Really!?!
Grug
June 02, 2010, 04:13:03 AM »
Quote from: DarkStaR on June 02, 2010, 04:06:55 AM
Really!?!
Yep
looks like the owner before me must have used superglue to stick the pad down when the edges lost their original adhesion.
I went to a panel beater down the road and we had a go at it with Prepsol, but no luck, the superglue isn't going anywhere.
Rockaduc, the clear pads will show the remaining bits of glue/pad I'm afraid, so that won't work. I just noticed the "Gripster" pads though, that might do the job. I'll have to find out the dimensions.
DarkStaR
June 02, 2010, 04:19:38 AM »
This might be BS, but if it doesn't work, you could just use them in the kitchen after...
http://ezinearticles.com/comment.php?How-to-Get-Super-Glue-Off-a-Car&id=136833
I'd test it somewhere out of site first...
Last Edit: June 02, 2010, 04:22:33 AM by DarkStaR
June 02, 2010, 05:28:53 AM »
Quote from: Grug on June 02, 2010, 04:13:03 AM
Yep
I have an idea, but it's not for the faint of heart and may damage the finish more if the user isn't skilled.
Ask your body guy if he has a nib file. Cyanoacrylates, super glues, don't penetrate too much. If he can nib it off and then give it a scuff and buff you should be OK.
Grug
June 02, 2010, 03:47:21 PM »
Quote from: DarkStaR on June 02, 2010, 04:19:38 AM
We had some of those in the kitchen already! I tried it out... and got nada.
it didn't do a thing. That superglue could easily have been there almost a decade now, it's rock solid. Looks like I'm going to have to gently sand it down and I'm get something like the Techspec Gripster 'kit' from which I'll cut out an appropriate shape. I'm going to a Clark Rubber store to see if they have anything that'll do the trick, otherwise it's $65 for the damn Gripster kit.
God this has turned out to be a nightmare.
battlecry
On a silver black phantom bike...
June 02, 2010, 04:16:56 PM »
Listen to DP's suggestion:
http://www.eastwood.com/painters-nib-file-fine.html
June 02, 2010, 04:57:12 PM »
Quote from: battlecry on June 02, 2010, 04:16:56 PM
No one listens to me.
Grug
June 02, 2010, 05:03:50 PM »
Quote from: ducpainter on June 02, 2010, 04:57:12 PM
:p How would the nib file differ from just carefully sanding it down?
DarkStaR
June 02, 2010, 06:42:03 PM »
Maybe this will cover up the mess:
http://www.shift-tech-carbon.com/onlineshop/product_info.php?info=p157_TANK-PAD-MONSTER.html
Grug
Reply #14 on:
June 02, 2010, 09:22:15 PM »
Quote from: DarkStaR on June 02, 2010, 06:42:03 PM
I think it might be a bit short to cover everything.
I've picked up a sheet of high-density 3mm foam with adhesive backing, going to attempt cutting out the tank pad shape myself and see how that works, the end result should be pretty similar to the original pad that was on there (and the foam only cost $7.95!)
