February 06, 2025, 10:33:46 AM
800 engine work
Topic: 800 engine work (Read 3103 times)
hackers2r
800 engine work
June 04, 2010, 07:23:06 AM »
Does anyone on here have any experience with the following?
http://www.ducati-kaemna.de/cms_en/katalog.htm?&view=artikel&artikel=1864
http://ca-cycleworks.com/shop/catalog/ducati/engine.html
If so, what can be expected? Thanks.
loves ze desmodromics.
Re: 800 engine work
June 04, 2010, 10:00:45 AM »
look at Kopfjager's M800 turned 853 or something close.
Re: 800 engine work
June 04, 2010, 06:23:09 PM »
I have two sets of the 91mm pistons from CA-Cycleworks going together into 750 engines (799cc's). Both engines have yet to be completed, but I can say that the pistons are top-notch quality! The 800 overbored to 91mm yields 859cc's and is the limit on a stock crankshaft equipped 803 motor (800).
Feral 859
Re: 800 engine work
June 04, 2010, 07:10:21 PM »
I did the Mahle (859) kit in my 800 along with a few other minor changes. We have HP and Torque increases, along with a little weight savings.
More work is being done now, DS heads, 900 cams etc. etc. I did this work to make the bike different from the norm.
You could get a lot more bang for the buck by swapping in a 1000ds engine.
Re: 800 engine work
June 04, 2010, 07:13:55 PM »
If you live in the US I suggest you go with California Cycleworks. Chris knows his stuff and will work with you. Decent prices with excellent technical support, plus he is a board sponsor
xcaptainxbloodx
Re: 800 engine work
June 05, 2010, 12:02:52 AM »
you could get a s2r 1000 motor for 1500-3000 on ebay, get more power, a dry clutch and maintain the flexibility that comes with running a stock motor.
plus you can sell your 800 motor to make the difference
Re: 800 engine work
June 07, 2010, 10:39:10 AM »
You could use any DS motor as long as it isn't from a Multi or Hyper (won't fit with your Monster swingarm). A while back Chris from CA-Cycleworks mentioned that he had a DS 1000 for sale. You could check with him.
If you like the wet clutch of your M800, you could try a wet clutch DS1000 from a GT1000 or any 2008+ Sport Classic. I saw a DS 1000 from a GT1000 a few weeks ago on eBay. It may be re-listed.
It would be really cool to use the latest 1100 DS from a new generation Monster and install it in the classic frame, but I haven't seen any for sale yet.
Cider
Re: 800 engine work
June 07, 2010, 03:52:50 PM »
It's more than the motor, right? Don't you need the computer, wiring harness, extra coils & plug wires, throttle bodies, etc., etc., etc.?
Re: 800 engine work
June 07, 2010, 04:22:38 PM »
Quote from: Cider on June 07, 2010, 03:52:50 PM
no
Cider
Re: 800 engine work
June 07, 2010, 04:44:12 PM »
Quote from: ducatiz on June 07, 2010, 04:22:38 PM
no
How do you hook up the extra spark plugs? It seems unlikely that converting an 800 to a 1000DS is as simple as dropping in a new motor.
Re: 800 engine work
June 08, 2010, 04:14:56 AM »
To put a DS1000 motor in a bike with an 800, here's what you'll need:
DS1000 ecu (IIRC it's got different pin-outs than the 800 does) and you'll likely be adding pipes so getting it re-flashed is a good idea
DS1000 header for the proper rear suspension
DS1000 wiring harness & coils
DS1000 intake manifolds (from throttle bodies to heads)
You can re-use your throttle bodies (providing the throttle position sensors are the same as there are a couple different ones in use) and you can re-use your airbox if you choose.
Christian
Re: 800 engine work
June 08, 2010, 01:16:15 PM »
Wouldn't you also need a cluster and keys for the immobilizer to match with the new 1000DS ECU's immobilizer setup?
Re: 800 engine work
June 08, 2010, 01:57:06 PM »
If you get the DS ecu re-flashed, you can get the immobilizer turned off. No need @ that point for keys & cluster.
Christian
Re: 800 engine work
June 08, 2010, 01:58:49 PM »
Ah excellent point. I didn't see the re-flash mention.
