Chain is over lubed
Started by Airborne, June 05, 2010, 12:44:02 PM
Scotzman
greenmonster
Why clean a factory lubed chain?!?
Best lube there is for the purpose,
never caused me any problems... :o [roll]
Not even greasy rims.
M900 -97
MTS 1100s  -07
suzyj
Quote from: ducatiz on June 05, 2010, 05:23:02 PM
piss on it and wipe it with a bra
Best be sure it's your own bra though.
Airborne
Quote from: greenmonster on June 06, 2010, 02:04:31 PM
I figured it would fling. Normally I would agree, but this thing looks like it was just dipped in a bucket of white lithium grease.
Plus it would just collect dirt. I spent $130 bucks on the chain, basically put even more money into redoing the whole rear of my bike, had my bike apart for the last two months, so its going to look good, or else.
If it has excess factory packing then wipe it down with a shop towel.  I wouldn't put any liquid on it (other than pee cause that won't do anything)
I have used heavy chain grease to relube a chain before ( which takes hours to do it right) it is far better than anything you can spray but a major pita
DucNaked
My chain had a shit load of grease on it, just wiped it off with a couple of rags.
Triple J
I just wipe new chains off with a rag and ride the bike. It may fling a little, but nowhere near as bad as you'd expect. After a couple hundred miles you won't know it was ever there.
I also won't use WD-40 on an O/X ring chain (although just spraying it on a rag and wiping would be OK).
I just let it fling to create a protective film on the bike.
Makes fun rorschach-like designs on the Quat-D too.  [thumbsup]
Airborne
Quote from: lethe on June 07, 2010, 03:08:44 PM
I think I saw your bike up in PA last year, you could definitely use all the protective film you can get  [moto]
