Chain is over lubed
Started by Airborne, June 05, 2010, 12:44:02 PM
Airborne
I bought a new EK chain and the thing has enough lube on it to last a lifetime. I know if I put it on I'll just end up cleaning it off the bike instead of doing it now.
I just tried pressure washing it off and it just pushed it around. Can I soak it diesel? Is there anything that'll get rid of it?
I'd prefer to get it all off then just rewax it with Maxima.
2007 Monster S2R, Vespa GTS 300, 2023 Triumph Tiger 900 Rally Pro, Vino 125
lwszabo
if its that bad Kerosene, but  arag and WD40 will probally work well.
DesmoLu
I wouldn't do either diesel or kerosene; hat would just hurt the Orings.
Wd40 and a rag is the way to go, just make sure to reapply lube afterwards!
The factory lube didn't fling too badly on any new chain I ever installed.
It's always been more like a whitish grease.
Airborne
Quote from: ducpainter on June 05, 2010, 12:55:10 PM
Yeah, I think its just white lithium grease. Its totally caked on there, globbed on. I already got it all over the bike while pulling the chain thru the swing arm. Its a giant mess.
Mine didn't fling.
I'd moisten a rag with wd-40 or kerosene and just wipe a little off if it bothers you.
I think if you use enough to actually clean it it will be even messier.
DarkStaR
Quote from: Airborne on June 05, 2010, 12:44:02 PM
I just tried pressure washing it ...
Wouldn't that be bad for the chain?  Bad as in getting water passed the o/x rings.
DucHead
Quote from: DesmoLu on June 05, 2010, 12:49:59 PM
Kerosene is fine and is often recommended to clean chains (my Bandit manual recommends kerosene).
Ddan
Quote from: DarkStaR on June 05, 2010, 01:19:39 PM
That would be my thoughts as well.  I've also never had much fling from the factory lube.
Ducati Monster Forum at
www.ducatimonsterforum.org
bean clean. but it might remove all the lube.
booger
You got that backwards - WD40 is a penetrant that could make it past the o-rings. Diesel or kerosene is the way to clean any chain whether it be o-ring or otherwise. I'm surprised at how many people don't know this.
2001 M900Sie - sold
2006 S2R1000 - sold
2008 HM1100S - sold
2004 998 FE - $old
2007 S4RT
2007 Vespa LX50 aka "Slowey"
2008 BMW R1200 GSA
Quote from: bergdoerfer on June 05, 2010, 04:31:45 PM
You got that backwards - WD40 is a penetrant that could make it past the o-rings. <snip>
True, but only if you use it on the chain as a spray.
It works fine when sprayed on a rag to wipe down the chain in my experience.
hackers2r
OT_Ducati
99 M750, 94 900sscr, 75 xs650 street tracker
piss on it and wipe it with a bra
