August 17, 2024, 09:20:19 PM
CAM
What did you do today?
140
141
142
143
201
Topic: What did you do today? (Read 319613 times)
wasta
Re: What did you do today?
Reply #2100 on:
May 02, 2012, 07:20:06 PM »
A camel yesterday.
1999 Monster 900, 2009 YZF R1, 2008 BMW K1200GT
tocino
Reply #2101 on:
May 03, 2012, 06:32:11 AM »
You did a camel today?
rgramjet
Reply #2102 on:
May 03, 2012, 07:09:29 AM »
That is why they're called The Ships of the Desert!
-Sofadriver
imthestig
just cause your breathing don't mean your alive.
Reply #2103 on:
May 03, 2012, 07:20:30 AM »
i rode my bike and some 4 wheeled death trap..
06 Acura TL
99 Ducati M900s
tocino
Reply #2104 on:
May 03, 2012, 10:24:55 AM »
venomousr1993
Snapping Like a Squirrel
Reply #2105 on:
May 05, 2012, 06:34:16 PM »
Packed up the bikes, truck and trailer..enroute to NC in the morning for 2 days of Keith Code Superbike school.
WERA Expert #163
Leo Vince
http://www.leovinceusa.com/
Lucas Oil
http://www.lucasoil.com/
WoundedWear
http://www.woundedwear.org/
AXO
http://www.axo.com/us/
tocino
Reply #2106 on:
May 05, 2012, 07:31:58 PM »
De-electrofied the Guzzi. Luckily I was only 2 blocks from home. Was testing it after putting the shorty black mufflers back on (looks the business) and it lost all electrical. I'm guessing a relay or just a bad wire since the entire thing is out - no ignition, horn, lights. The only thing between the battery and lights is a relay and the fuze box, and all the fuses are good, so that narrows things down. I hope
tocino
Reply #2107 on:
May 05, 2012, 07:32:49 PM »
Quote from: venomousr1993 on May 05, 2012, 06:34:16 PM
Omnipotent Potentate
Personal Pretext
Reply #2108 on:
May 06, 2012, 03:19:23 AM »
Quote from: tocino on May 05, 2012, 07:31:58 PM
Check for a main fuse. I know ducs have a fuse box AND a 30 amp main in a different spot. That main pops and all powers cut
TitanMonsterS4R
Reply #2109 on:
May 06, 2012, 05:38:16 AM »
tocino
Reply #2110 on:
May 06, 2012, 05:45:40 AM »
Quote from: Slide Panda on May 06, 2012, 03:19:23 AM
Here's the wiring digram I'm working from:
The Mad King Pepe'
Reply #2111 on:
May 06, 2012, 03:10:43 PM »
Changed tires and tubes in the GS: got a pair of Shinko 705 on the outside and IRC heavy duty on the inside.
Breaking the bead on the front was pretty easy (just by standing on it), but the rear was a real pain. Jumping, whacking with a rubber mallet, and sidestand method didn't work, I had slowly pry it off with the irons!
The proper way to inflate a tire!
No pics of working on the rear, but this is pretty close!
In the end it all worked out fine so
for me!
Meerkat
When I'm not playing Silver Power Ranger, I'm a
Reply #2112 on:
May 06, 2012, 04:26:09 PM »
Quote from: The Mad King Pepe' on May 06, 2012, 03:10:43 PM
I've found that car jacks work pretty well as bead breakers, when shoved under a pipe protector in my condo garage.
'07 S2R1K
'09 Daytona 675
'03 620 Dark-Sold 03/26/2011
tocino
Reply #2113 on:
May 06, 2012, 07:19:51 PM »
Re-electrofied the Guzzi. Must've caught a wire to the ignition relay jack taking-off/putting back the tank at some point and slightly pulled it out. Wiggling wires and watching the power flicker led me too it. I did the highly technical toss-o-the-offending-bit and just wired directly to the relay. Not sure why I put the jack in anyways.
Oh, and I get some advice yelled at me by some horse-trailer lady. Or maybe she meant one of the n'er do wells standing next to me.
Moderator
Reply #2114 on:
May 06, 2012, 07:49:08 PM »
You had better be careful.
140
141
142
143
201
