February 04, 2025, 12:35:26 AM
CAM
Metro DC! Who's up for a ride this weekend?
91
92
93
94
105
Topic: Metro DC! Who's up for a ride this weekend? (Read 211022 times)
Meerkat
When I'm not playing Silver Power Ranger, I'm a
Re: Metro DC! Who's up for a ride this weekend?
Reply #1365 on:
January 07, 2012, 03:34:47 PM »
'Nuff said: Italian electronics
'07 S2R1K
'09 Daytona 675
'03 620 Dark-Sold 03/26/2011
Moderator
Reply #1366 on:
January 07, 2012, 04:25:21 PM »
make the beast with two backser!
Meerkat
Reply #1367 on:
January 07, 2012, 04:29:59 PM »
Quote from: DRKWNG on January 07, 2012, 04:25:21 PM
I was just the first to get mine posted...I hear there are other pictures of that piece of trade-in material! How was the ride home?
'07 S2R1K
'09 Daytona 675
The Mad King Pepe'
Reply #1368 on:
January 07, 2012, 04:55:48 PM »
Quote from: Ducatician on January 07, 2012, 03:34:47 PM
WTF happened?
Moderator
Reply #1369 on:
January 07, 2012, 05:02:14 PM »
Quote from: The Mad King Pepe' on January 07, 2012, 04:55:48 PM
WTF happened?
Not sure yet, but it looks like the alternator decided not to alternate.
Meerkat
Reply #1370 on:
January 07, 2012, 05:26:12 PM »
Quote from: DRKWNG on January 07, 2012, 05:02:14 PM
I'm still in for voltage regulator.
'07 S2R1K
'09 Daytona 675
Moderator
Reply #1371 on:
January 07, 2012, 05:53:33 PM »
I swapped regulators while we were out there, nothing. Put the bike on the tender as soon as I got it home, twenty minutes later and it's trying to turn over. Pretty sure the alt quit alt'ing and the battery drained to the point where it wouldn't run the bike any longer.
On a lighter note, remember how dilated Randy said his ass was after Lars almost hit that car?
Meerkat
Reply #1372 on:
January 07, 2012, 06:11:22 PM »
Quote from: DRKWNG on January 07, 2012, 05:53:33 PM
Let's hope PePe doesn't try to find a picture...
Of course there would be nothing when you swapped the regulator if it caused the battery to drain...putting the other regulator on there wouldn't help. I'm still in for a shit regulator...there's a really good guide to figuring it out here:
http://www.electrosport.com/technical-resources/diagnosis-center/fault-finding-guide
If you don't have a volt ohm meter, I've got one or you can pick one up for dirt cheap at HF.
'07 S2R1K
'09 Daytona 675
venomousr1993
Snapping Like a Squirrel
Reply #1373 on:
January 07, 2012, 06:35:10 PM »
If the battery is the original, I would change that too as insurance. Just don't buy the gel Bikemaster one...total junk and was trash in a few months. I trust the Yusa batteries....I also have a Ballistic 8 cell 1.8lb battery in the track bike that works well too.
How was the ride back Ben??? No party in the backseat???
Last Edit: January 07, 2012, 06:47:21 PM by venomousr1993
WERA Expert #163
Leo Vince
http://www.leovinceusa.com/
Lucas Oil
http://www.lucasoil.com/
WoundedWear
http://www.woundedwear.org/
AXO
http://www.axo.com/us/
Moderator
Reply #1374 on:
January 07, 2012, 06:55:40 PM »
Dude, they Barry White and a disco ball going on in there.
Meerkat
Reply #1375 on:
January 07, 2012, 07:08:58 PM »
Quote from: DRKWNG on January 07, 2012, 06:55:40 PM
I didn't get to see if she had teeth...
'07 S2R1K
'09 Daytona 675
zooom
Reply #1376 on:
January 08, 2012, 03:43:13 AM »
Quote from: Ducatician on January 07, 2012, 06:11:22 PM
+1 to this...sorry for the suckage...at least you aren't bikeless...you can still hump the StuperDuke in the meantime...
2010 KTM 990 SM-T
Moderator
Reply #1377 on:
January 08, 2012, 03:56:28 AM »
Main reason I'm (almost) discounting the regulator theory is because the one on the bike currently was tested with the Ducati diagnostic dohicky on Friday evening. It was putting out 13.6 volts. Sure, it could have shit itself right afterwards, but...
zooom
Reply #1378 on:
January 09, 2012, 04:25:54 AM »
Quote from: DRKWNG on January 08, 2012, 03:56:28 AM
did you test it with a volt meter and a pin probe directly into the wires themselves?...Ducati is famous for dodgey electrical connectors in terms of the regulators and wiring and you'll see things moreso when you follow the electrosport falt tracing....it was exactly what I used to figure out what was going on with the charging system on the Gran Canyon....and then I finally replaced the wiring and connectors from the RR to the Stator/Alternator...as much of it as I could...aprox 10-12 feet of heavier guage wiring...this was a contributing factor as to why I needed to be roll started by you guys at that cold Bowie run that one time....and it started snowballing from there...
2010 KTM 990 SM-T
The Mad King Pepe'
Reply #1379 on:
January 09, 2012, 06:26:07 AM »
1. Get a voltmeter: Advance Auto, Radio Shack, pretty much any place should have them (About $10);
2. Connect the battery so you can crank the engine;
3. Set the voltmeter to AC: alternating current (not air conditioning), symbol looks like a sine wave -- two tits, one up one down with a line through them);
4. Put one of the voltmeter contacts in each hole in the alternator wire (doesn't matter which order) connector. There's three holes total, so pick two, then test the other one.
5. Crank the engine. If the voltmeter doesn't measure any current then the alternator is no good (or you're doing it wrong
91
92
93
94
105
