September 16, 2024, 10:18:26 PM
NorthWest
Mother's Monster
Topic: Mother's Monster (Read 3124 times)
GAAN
Mother's Monster
June 21, 2010, 04:31:28 PM »
40,480 miles and she can limp no farther -
It's ALIVE
- 40,865 miles
gone are the band-aid repairs
she needs real work now
Ignore this
I'm just putting it in a place I will remember
Needs
Clutch
Valve Adjustment
Throttle Body Sync
Dyno
Rear Wheel Bearings
Plugs
Plug Wires -
Done
(what a PITA)
All Rubber Hoses
Fork Seals
Would like:
POR-15 Marine Clean
Rear Strada -
Done
Un-integrate tailights -
Done
Rear Signals -
Done
Belts -
Done
Chain -
Adjusted
Sprockets 14/46 -
Checked
Crank case Breather Valve -
Done
K&N Breather Filter -
Done
Rectifier Relocator -
Done
Oil -
Done
Filter -
Done
Rear Brake Pads -
Done
Rear Rotor -
Checked
Front Pads -
Checked
Front Rotors -
Checked
Projects:
Chop Belt Covers -
Done
Hide/Clean Up wires:
In Progress
Taillights & Rear Siganl Harness -
Done
Headlight & Front Signal Harness -
Done
Brakelight & Speedo Harness -
Done
Cut Brackets and Mounts
Lower Guages -
Done
Dyno Map PC-III
Wants:
Spare set tires Pilots or Stradas -
Done
PTO Beast Pod filters -
Keeping the box for now
Galassetti OMOLOGATO slip ons
Adjustable Front Forks -
Done
Upgraded Rear Shock
5 spoke marchesinis 5.5"
Oil Cooler S4R Style (low mount)
Dry Clutch Conversion
And real Paint -
Done or as done as it's ever going to get
Last Edit: August 12, 2010, 01:58:10 PM by Mother
krolik
Yeah, that's me. So what.
Re: Mother's Monster
June 21, 2010, 07:13:33 PM »
How'd you fix the crankcase breather valve?
Quote from: SacDuc
GAAN
June 21, 2010, 07:24:41 PM »
Quote from: krolik on June 21, 2010, 07:13:33 PM
i stole the one off Big E's supersport
then i found out it went to speeddog and i felt bad
June 21, 2010, 10:32:53 PM »
How did you lower your gauges? I lowered the light some time ago but not the gauges.
krolik
June 22, 2010, 07:19:19 AM »
Quote from: D Paoli on June 21, 2010, 10:32:53 PM
Lowering the gauges
is his euphemism for crashing.
Quote from: SacDuc
GAAN
June 22, 2010, 11:31:56 PM »
I took the guage pod off
then took all that crap that the pod was connected to and tossed it
then I bolted the pod directly to my top triple
the only real issue is that it is a pita to unbolt the pod since the bolt heads are under the triple
it is easier to just pull it off then unbolt the pod
I am using a Cycle Cat Top Triple so I am not sure if you can do the same thing with the stock triple
I am alswo thinking for long term survivability it may not be the best thing to do since it removes the vibration dampeners
ryandalling
Trade you my milk for your Ducati...
June 23, 2010, 02:35:01 AM »
Oh I thought this was a thread about Jbub... you know... "Mother's Monster" ... bwa ha ha ha ha ha
I am so funny....
Jess... I am just kidding.
You two need to come off the mountain more.
Confused rider who doesn't know what he is even riding at the moment. (2012 URAL GearUp, 2012 Ninja 250 Racer, 1969 CB175 Racer)
JBubble
June 23, 2010, 07:39:53 AM »
Y'all can always head up here too....
Bendy
June 23, 2010, 09:54:16 AM »
It's not frowned upon up there to say that the Whistle Post has good fish and chips, is it? 'cause they do.
GAAN
June 23, 2010, 01:29:20 PM »
Whistle stop
they do in fact
the place has increased significantly since they banned smoking in bars
Bendy
June 23, 2010, 02:27:37 PM »
My mirrored visor makes me lysdexic.
