February 06, 2025, 12:35:08 PM *
Pages: [1] 2   Go Down
Author Topic: R&G Tidy Tail - M696/M1100  (Read 4619 times)
theprocess
'09 M696
« on: June 22, 2010, 05:27:14 PM »
Did anyone have issues with lining up the 4 screws used to attach the two pieces?   Looks like the bottom piece is too wide...need to squeeze the side in a little or make the hole bigger so it lines up with the other one (threaded).  Cant squeeze the sides in because its folded and blocked by the angled panel (closest to the front of the bike)...make the hole bigger?
« Reply #1 on: June 22, 2010, 06:47:23 PM »
i used a rubber mallet to push it out enough to get the holes lined up. but i didnt use the back small screws. I used those holes to run the wires
Veloce-Fino
Wiggle-Jiggle
Bike sold - But I'm still lurking.
« Reply #2 on: June 22, 2010, 07:04:06 PM »
(Pulled from other thread)
*this is what I had to do to get theR&G tail tidy to fit.
Ok Below are the photos of where I ground off some of the plate with a standard bench grinder. Most of the grinding was done on the vertical surface but also some on the "corner" of the bracket half.
The Photo below gives the best idea of where I ground the plate to make a perfect fit. Touch up with some black paint and your golden.
Is this thing on?
z0mb1e_DUC
« Reply #3 on: June 23, 2010, 02:43:38 AM »
Definitely alignment issues with the kit.
I went the route of actually bending those wings up a little, to clear enough room to run the wires.   I also bent the tab with the two front holes some, it helped line things up.  Then I ran each screw in 1 to 2 turns until I got everything to line up & tightened it all up.  You gotta give it some "love" to get it together right.
« Last Edit: June 23, 2010, 02:52:50 AM by z0mb1e_DUC » Logged
'09 m696 Dark
theprocess
'09 M696
« Reply #4 on: June 23, 2010, 03:15:14 AM »
@WinSomeLoseNone - thanks for the pics and description of your fix.
Looks like there are others with alignment issues with this kit.  For the price charged on these I would have expected a perfect fit and better quality control.  The parts don't fit together!
theprocess
'09 M696
« Reply #5 on: June 23, 2010, 09:37:19 AM »
@WinSomeLoseNone - Is it possible to just bend the side pieces up to create a gap for the wires? Looks like theres plenty of clearance before the brake light.  I think this is what z0mb1e_DUC did for the wires.
« Last Edit: June 23, 2010, 09:40:58 AM by theprocess » Logged
Veloce-Fino
Wiggle-Jiggle
« Reply #6 on: June 23, 2010, 06:07:23 PM »
Possibly but the brake light actually contacts the bracket at the bottom of the light where it comes to a point. So you would need to bend just the ends of the bracket on 1/4 inch aluminum plating. Difficult but possible.
Is this thing on?
desmoworks
« Reply #7 on: June 24, 2010, 07:36:08 AM »
Have any of you guys notified R&G of this issue? I'm sure they'd want the feedback so they could correct it as they generally offer great kits that fit easy. Wonder how this one became an issue!
Anthony Creek
Pro Italia Online || mota-lab
« Reply #8 on: June 24, 2010, 08:03:29 AM »
Actually I did notify them via their site. even got a reply. maybe they thought it was an issue from me only?
Veloce-Fino
Wiggle-Jiggle
« Reply #9 on: June 24, 2010, 09:16:16 AM »
Contacted them today just to let them know I also had the issue.
Is this thing on?
theprocess
'09 M696
« Reply #10 on: July 02, 2010, 11:47:32 AM »
Any word back from R&G?  I contacted the place I bought the kit from, waiting for response.
Update on the kit I got - Not only do the 4 screw holes not align, but also the 4 holes for the posts that come from the tail plate (attached to subframe).  If the posts arent allowed to fully pass through the 2 pieces then the tray cannot mount flush to the tail plate.  This kit is a complete fail!
« Reply #11 on: July 02, 2010, 11:50:48 AM »
send it back. seriously. let R&G see the issues. give them a chance to make restitution and fix the problem for future buyers.
Veloce-Fino
Wiggle-Jiggle
« Reply #12 on: July 02, 2010, 05:07:14 PM »
+1
they responded and said they were happy with the kit and the problem would be forwarded to the manufacturing department... aka they will do nothing.
send it back.
Is this thing on?
00Kevin
« Reply #13 on: July 06, 2010, 07:16:53 AM »
Sounds like it's more trouble than it's worth. I was considering one of these, but think i'll look at something else that won't be such a hassle. Thanks for the posts.
'09 Monster 696 Red
Veloce-Fino
Wiggle-Jiggle
« Reply #14 on: July 06, 2010, 07:56:27 AM »
If not R&G the next best build quality kit is the Evotech one. Almost identical to the R&G but without the install issues.
Is this thing on?
Pages: [1] 2   Go Up
