Engine Case Cover Bolts - Belly Pan Install
Started by theprocess, June 22, 2010, 06:55:15 PM
theprocess
Not sure if this is the right section to ask but here goes.
All of the belly pans Ive been researching mount the M696/M1100 by using the engine case cover bolts on both sides.  Does loosening/removing these bolts crack the seal?  Is there a chance of oil leaks developing even if torqued back to spec?
I've never encountered a leak from removing case bolts for that purpose.
theprocess
