Started by DRKWNG, June 27, 2010, 08:24:17 AM
Quote from: duc_fan on September 18, 2013, 03:31:22 PM
The SR-71 was designed on paper... and the math was all done on slide rules.  This is an airplane that goes mach 3 at 80,000 feet... the thermal expansion of the panels had to be calculated such that the metal expansion resulted in a perfect fit at altitude and speed, which resulted in it leaking like a sieve on the ground.
Never ceases to amaze me.
+1
never seen one close range . . .
That's one bad ass plain right there!  There's one on static display at one of the locations where I work sometimes.  It's amazing to sit and think that the aircraft was designed in the 50s and 60s and still out performs and and all aircraft to this day.
I went to see some of the space stuff they have in Florida and when I look at the command module with its old antiquated stuff, it is just amazing that three men went to the moon in that thing.
Also it went way faster than the SR71
Then compare that to the way the 777 is built. It's all so much nicer. Designed in a computer then built. You can tell when your working on it, how everything was thought of before hand.
Quote from: DRKWNG on September 18, 2013, 03:49:45 PM
That's one bad ass plain right there!  There's one on static display at one of the locations where I work sometimes.  It's amazing to sit and think that the aircraft was designed in the 50s and 60s and still out performs and and all aircraft to this day that we know of
rgramjet
Theres a Blackbird on display at the Udvar Hazy museum in VA.  Awesome.
-Sofadriver
Quote from: Darkmonster620 on September 18, 2013, 06:23:38 PM
Blimey!  Yonder landlubberin' Cap'n be a scuttlin' that Sloop an' feeding t' fish soon if 'e be not chargin' t' bilge pumps smartly like!!
Aaarrrrgggghhhh!
zooom
Quote from: ungeheuer on September 18, 2013, 06:36:13 PM
Aaarrrrgggghhhh!
you smartly be speakin matey speak for the days parlay....
2010 KTM 990 SM-T
How many front ends, and which ones, did they splice together for that?
Spittoons for velocity stacks?
spolic
All this talk and no pic.
In the Boeing museum in Seattle they have a cockpit of a SR-71 that you can sit in.
muskrat
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
