January 29, 2025, 09:21:08 PM *
Author Topic: Power Commander 5 maps for M696??  (Read 6385 times)
loopsrider
« on: June 28, 2010, 02:57:35 PM »
Got my Power Commander 5 intsalled on my M696 tonight and went ahead and tried to download a few maps from the power Commander database and their is none for my model of bike??? I checked for other models of the Ducatis and they had them...
Are there no maps available for the 696 from Power Commander?? Huh?
 I was at the understanding that they had a few map configurations for the 696...hope I'm not wrong.... bang head
chisel
« Reply #1 on: June 28, 2010, 04:19:45 PM »
I notice on this page:
http://www.powercommander.com/powercommander/powercommander_v.aspx?mk=5&mdl=289&yr=2009
there is an exe you can download. The exe unzips 2 files, pvm files, which I believe are Power Commander map files.
Here's how they list them:
  M14-001-000    Zero Map
  M14-001-001    Stock exhaust, Stock air filter
Now, whether or not those are worth a damn, I don't know. But, they are there...
« Reply #2 on: June 28, 2010, 07:10:38 PM »
yeah i think we're going to have to supply the maps to them at first or build a database ourselves.
loopsrider
« Reply #3 on: July 01, 2010, 04:58:29 AM »
I agree Raux... Doesn't seem to be a lot of support from the manufacturers... might be a good idea to start some kind of data base...
I had completelt missed those maps on their site Chisel...thanks waytogo. The cd they send with the PC V didn't have the maps you had found on their site...
Anyone care to take a stab at what they have done with the second map? I'm assuming the map with the cells zeroed is the stock map??
Looks to me that they have richened the bottome end up slightly but the lean spots they have mapped seem strange??
ZERO MAP CYLINDER 1 (M14-001-000)
STOCK EXHAUST STOCK AIR FILTER (M14-001-001)
« Reply #4 on: July 01, 2010, 06:01:47 AM »
probably to help smooth out the power curve, have you seen that thing !
loopsrider
« Reply #5 on: July 04, 2010, 07:03:16 AM »
Yeah, I agree...I find it pretty peaky and I am hoping to smoothen out the powerband a little. Stock curve is great for hooligan riding at 5000-8000 RPM but putting through town is pretty finicky...
FWIW, I uploaded the second map and I seem to be getting a little surging @ 3000 RPM under 20% throttle. Cleans up @4000 RPM. I will try moving the numbers around and giving it another try if this damn rain ever stops.... Roll Eyes
« Last Edit: July 04, 2010, 07:05:52 AM by loopsrider » Logged
theprocess
'09 M696
« Reply #6 on: September 02, 2010, 04:58:40 AM »
2 more maps from the PC webpage.  http://www.powercommander.com/powercommander/powercommander_v.aspx?mk=5&mdl=289&yr=2009
M14-001-502  European Model Termignoni race slip-ons (DbKiller removed) Stock or aftermarket air filter Stock ECU O2 Optimizers installed
M14-001-503  European Model Termignoni CE approved slip-ons (DbKiller installed) Stock or aftermarket air filter Stock ECU O2 Optimizers installed
Is there a map available to smooth out the below 4,000rpm roughness?  Would make commuting in the city more bearable.
metroplex
« Reply #7 on: June 15, 2013, 09:18:32 AM »
Those maps indicate "Stock ECU"
Does that mean the stock factory ECU, or the DP ECU? I'm assuming that since I have the full Ducati Performance kit (Carbon Termi's, no dB killer, performance air filter) with the DP ECU that if I loaded a map intended for the stock ECU it will not correctly adjust the fuel trims... So where are the Dynojet maps designed for the DP ECU?
Or do I need to switch back to the stock ECU?
These aren't the droids you're looking for
