fork clamp size for 696
Started by jonnyconcrete, June 30, 2010, 03:49:02 AM
jonnyconcrete
what fork clamp do i need for a 696
i did a quick search and couldn't see a thread jumping out at me
are they 50mm ?
looking at fitting a custom light setup
what
they are 50mm at the top fork clamp and 54 at the bottom fork clamp.
jonnyconcrete
#2
Quote from: Raux on June 30, 2010, 07:41:26 AM
what
sorry maybe i did something wrong i roughly measured the bottom of the fork at 173mm this is where im attaching a clamp (near where the black bottom clamp is now). which gave me the circumference i then worked out the diameter i must have gone wrong somewhere in my first equation or i must have mis measured ..god knows ? i divided this by 3.14 (pi)  that gives me 55.095 i must have failed first time round or something in the measuring conversion process.
NoisyDante
The math is sound, as circumference divided by pi equals the diameter, though the top fork is 50mm and the bottom is 54mm.
Concurrently the diameter multiplied by pi should give you the circumference . . .
