February 06, 2025, 10:20:58 AM
Brake light stuck on
Topic: Brake light stuck on (Read 1262 times)
factorPlayer
July 03, 2010, 06:28:39 PM »
well I just finished the tail chop and put in an integrated tail light, but now the brake light is stuck on. At least the indicators work. Going to get dirty with it again tomorrow... any suggestions?
DarkStaR
Re: Brake light stuck on
July 03, 2010, 06:34:32 PM »
Test the wires. Some/One of the manufactures color code the wires wrong.
July 03, 2010, 07:46:13 PM »
chances are u wired it backwards. you gave the running light power to the bright stop light.
July 04, 2010, 02:13:57 AM »
Or put the bulb in backwards. Or, perhaps, coincidence. If the bulb is in correct and wiring is also correct, disconnect each switch to isolate the problem.
July 04, 2010, 02:19:42 AM »
Quote from: He Man on July 03, 2010, 07:46:13 PM
That's what I did at first
mookieo2
July 04, 2010, 03:37:49 AM »
Disconnect the switches as Howie said. It happened to me. I took my light off at the track and when I put it back on at home the light wouldn`t shut off. Somehow the rear brake switch shorted out. I disconnected it and it and it worked fine with the front. One day I might even replace the rear switch.
