February 06, 2025, 06:41:20 PM
SBK front fender for M695
Topic: SBK front fender for M695 (Read 3391 times)
tristantumble
July 07, 2010, 06:02:44 AM »
I'd like to put on a more aggressive front fender, and I've seen some great deals on ebay. Before i pull the trigger, i'd like to know which fender off what ducati SS models would fit my bike... if any? Also will it require modification, or is it a straight swap?
Thanks.
07.695 (sold)
07. sport 1000 biposto
Omnipotent Potentate
Personal Pretext
Re: SBK front fender for M695
July 07, 2010, 06:24:58 AM »
If I remember correctly, it's a 748 916 996 998 style of fender that fits Monsters
supertjeduc
July 07, 2010, 07:18:12 AM »
848 and 1098 also fits
tristantumble
July 07, 2010, 07:31:52 AM »
is it a straight bolt deal or are modifications necessary?
07.695 (sold)
supertjeduc
July 07, 2010, 07:47:39 AM »
I don't know how your plastic thingies look like
There are two sorts , straight ones and the other type
When you have the straight ones the gap between tyre and fender could be a Little to big (for the looks)
The other ones you can flip over and Will be fine
But it's a straight bolt on
DarkStaR
July 07, 2010, 07:56:30 AM »
Quote from: supertjeduc on July 07, 2010, 07:18:12 AM
+1
Quote from: tristantumble on July 07, 2010, 07:31:52 AM
should bolt on
Quote from: supertjeduc on July 07, 2010, 07:47:39 AM
If I'm not mistaken, from all the ones I've seen, the black ones are off-set (higher or lower depending on how they are mounted), and the white ones are straight.
Last Edit: July 07, 2010, 07:59:53 AM by DarkStaR
supertjeduc
July 07, 2010, 08:44:30 AM »
Quote from: DarkStaR on July 07, 2010, 07:56:30 AM
+1
should bolt on
Could be so , you can switch those black ones from left to right , the gab between tyre and fender is better than
tristantumble
July 07, 2010, 09:04:26 AM »
whats all this talk about colour... fill me in?
07.695 (sold)
July 07, 2010, 09:42:07 AM »
Quote from: tristantumble on July 07, 2010, 09:04:26 AM
look tat the black plastic strips around the lowers on the forks. some are yellowish clear and others are black. those are the mounts.
the newer bikes have the mounts as part of the lowers
Mr.Saturn
July 13, 2010, 09:15:35 PM »
Picked up a flat black 848 fender on eBay for $30 shipped, looks awesome on the bike!
DucatiBastard
"Apollonia" '06 S2R 800
September 04, 2010, 06:09:08 AM »
Does anybody know if the Hypermotard 'fenders' will fit onto 1098 forks? The ones that just cover the fork slider.
From quick research the mounts look offset on the hyper and straight on the 1098, but I'd like to be sure
edit-sorry about the zombie thread, but i figured having lots of info bout fenders in one place is better
Last Edit: September 04, 2010, 06:11:01 AM by DucatiBastard
Give a man a beer, and he wastes an hour.
Teach a man to brew, and he wastes a lifetime.
2006 Ducati S2R 800, 2004 Honda Dream 50R, 2001 Kawasaki W650, 1940 BSA M20
geoffduc
18 till i die
September 04, 2010, 09:59:52 AM »
The mounts on the hypermotard are off set and the mounts on the 1098 are straight, the 1098 front mudguard fits alot of monsters, I've had one on an S2R and an S4r without any problems but the S4Rs is totally different in that it has one bolt in front and one bolt behind the bottom of the fork leg.
2015 scrambler FT
2009 monster 1100s
DucatiBastard
September 04, 2010, 04:10:08 PM »
Hmmm, I wonder if the Hyper 'fenders' will fit with a longer bolt and a small shim of aluminum or similar tube through the top mount...
To clarify I am putting 1098 forks (courtesy of TAftonomos) onto my S2R and like the look of no fender but want protection for the sliders
ducmon695
September 10, 2010, 06:08:22 AM »
Ok So i looked at my 695 Dark and I don't have white or black mounting clips on the bottom of the forks...I have dark grey. Will a SBK fender still work?
2002 Desmohio/Cycle Cat 900ss Cafe
DarkStaR
Reply #14 on:
September 10, 2010, 06:44:28 AM »
Quote from: ducmon695 on September 10, 2010, 06:08:22 AM
Should still work. If they are off-set, you can swap left to right for more clearance.
