rizoma rear set for ducati monster 1100s abs
Started by torck, July 12, 2010, 06:56:24 PM
torck
Hi, does anyone have a Ducati monster 1100s with abs and has the Rizoma rear set installed. If so was it an easy install?
Heath
#1
Pretty good write up here
http://ducatimonsterforum.org/index.php?topic=38078.0
He got them and they didn't work.  Had to get a different brake line if I remember correctly.
2007 Ducati Monster S4RT
Amlethae
Yup requires a new brake line because of the new brake MC placement on the Rizoma vs. stock (might call for a new ABS brake line as well, but I can't remember).  Also then calls for bleeding the ABS system which apparently is a bit of a 4 day job and the bike is unridable until it's bled.  My suggestion is let a mechanic deal with it (because of the ABS aspect).
monsteristi
the best way to get this finally solved, without tweaks and own custom installation on the ABS system, is to directly write an email to rizoma. You find their contacts on the hompage. As more people are requesting this, as sooner it will get solved.
