January 06, 2025, 06:08:54 PM *
Author Topic: CRG Clutch Lever Plungers & Barrels-Update/note  (Read 1490 times)
RAT900
« on: July 14, 2010, 03:24:00 AM »
If anyone has attempted to upgrade their pee-cup Brembo clutch master cylinders to CRG levers ..........
they may have come up against the problem of removing the barrel and plunger shaft from the old take-off lever.
Between the epoxy and the locktite'd grub screw it is close to impossible
I found a supplier of these parts so you don't have to buy an entire spare OEM lever just to get the plunger and barrel assembly
Here's the link:  http://www.af1racing.com/store/Scripts/prodView.asp?idproduct=7756
« Last Edit: July 15, 2010, 05:44:35 AM by RAT900 » Logged
minnesotamonster
« Reply #1 on: July 14, 2010, 03:38:21 AM »
This is awesome. Nice find. I looked and looked this winter but ended up having to buy a new clutch lever off fleabay.
Thanks for posting!
2004 S4R
1998 Honda F3 (Track)
2001 M600 (Now the Wife's)
RAT900
« Reply #2 on: July 14, 2010, 03:47:29 AM »
Thanks for posting!
I really have to give credit to Jeff at Monsterparts.com for the tip. He is good people and a wizard on our bikes
chixstrip
« Reply #3 on: July 14, 2010, 05:27:01 PM »
Sweet!! Been using metal-to-metal cement to hold mine tight since i ripped it open.
RAT900
« Reply #4 on: July 15, 2010, 05:48:49 AM »
OK I just got mine and installed the CRG lever
Please note that the barrel does not have an extension on it for the clutch cutoff switch so your bike HAS to be in Neutral in order for the starter button to work.
Practically speaking if you stall when taking off from a light, you cannot just pull in the clutch lever and hit the starter with the bike still in gear.
You will have to move it back to neutral in order to get the starter to engage
If that represents a problem I am sure you can epoxy a leg of some sort on the bottom of the barrel to activate the switch
