February 06, 2025, 05:54:19 PM *
News: Please Help
Pages: [1] 2   Go Down
Author Topic: Oil Cooler Options  (Read 4189 times)
« on: July 14, 2010, 02:00:42 PM »
I busted my oil cooler today, its 100% toast i just spit out atleat 1/2 quart of oil today.
the NCR one is too expensive for my taste, are there other options other then a stock one off ebay or welding it?
Ducatl
« Reply #1 on: July 14, 2010, 02:20:44 PM »
I suppose you could purchase any number of aftermarket options and weld your own tabs to make it fit? I mean...if we're already talking about welding anyways Wink
« Reply #2 on: July 14, 2010, 02:39:37 PM »
Im not sure if its even practical to buy another one. I was just going to rent a tank of argon tommorrow and run a pass through the inlet/outlet area and call it a day. i think thats where its leaking.
Goat_Herder
« Reply #3 on: July 14, 2010, 02:40:17 PM »
How?   popcorn
Goat Herder (Tony)
pennyrobber
« Reply #4 on: July 14, 2010, 02:40:24 PM »
There's the S4R option. (minor mods required)
« Reply #5 on: July 14, 2010, 02:41:07 PM »
There are M14x1.5 to AN-6 fittings which would adapt your engine outputs to AN-6.  At that point, any number of aftermarket options become open to you.
« Reply #6 on: July 14, 2010, 03:05:39 PM »
How?   popcorn
dont make too much popcorn cause i dont know. I hang my oil cooler with a wire 90% of the time when i remove it. theres maybe 10% of the time where i let it sit on my fender. Maybe thats what caused it? but i dont know for sure where its leaking yet. im cleaning it up leting it dry and throwing some baby powder at it.
duckstew thats good to know, i will see what well priced options are out there. pennyrobber, that looks way to small. I already run stupid hot in the city, i dont need a smaller oil cooler. maybe a bigger one!
« Last Edit: July 14, 2010, 03:38:48 PM by He Man » Logged
battlecry
On a silver black phantom bike...
« Reply #7 on: July 14, 2010, 03:15:35 PM »
Check out Earl's products at Amazon.  Here is an example:
http://www.amazon.com/Earls-21006ERL-Row-Oil-Cooler/dp/B000A8JJ3Q/ref=sr_1_1?ie=UTF8&s=automotive&qid=1279156251&sr=8-1
lofty55
« Reply #8 on: July 14, 2010, 05:30:06 PM »
My oil cooler has a nasty leak on the right side where the hose meets the oil cooler. i dunno if it is the hose or the cooler but i am definitely interested in an aftermarket solution. NCR has dope stuff but its expensive. I also found an oversized cooler here:
http://www.motowheels.com/italian/myProducts.cfm?parentcategoryid=1054%7CMonster%20Engine%20%26%20Performance&productID=2770&showDetail=1&categoryID=1077|Monster%20%20Engine%20Cooling&vendoridtodisplay=0&filterFor=&collection=168%7CEuropean%20Motorcycle%20Parts
Looks like they are out of stock though. That one is still expensive.
Let us know what you come up with so i can copy it!   Grin
This is more fun than standing still at a radiohead concert.
'07 S2R1K
'02 998
« Reply #9 on: July 14, 2010, 06:50:40 PM »
There are 2 O-rings on the inlet fittings into the cooler as well as one crush washer between the inlet fitting and the cooler housing.  Any of those three could be your issue.
lofty55
« Reply #10 on: July 14, 2010, 07:07:22 PM »
Thats what my mech thought too but after replacing the o-rings, it still leaks. Maybe the crush washer? My bike has been knocked over by drunks trying to parallel park in my neighborhood. make the beast with two backsing night clubs! Im thinking it may have cracked something.
'07 S2R1K
'02 998
« Reply #11 on: July 14, 2010, 07:11:56 PM »
isnt ryanracer set up to sell oversized oil coolers?
Javamoose
« Reply #12 on: July 14, 2010, 07:13:46 PM »
So, looks like the aftermarket ones are about 10 row, single pass.  I'm assuming they are flat tube and folded fin construction for the core?  Anyone know the tube diameter on the radiator flow tubes in the core?  Also, what's the internal pressure these radiators are subjected to?
EDIT:  The reason I ask is that I have a supplier for high quality full copper cored radiators that I used at my last job, they are super nice, well built and come powder coated - BUT - they are only rated to about 30 psi.
« Last Edit: July 14, 2010, 07:18:13 PM by Javamoose » Logged
2000 M750
pennyrobber
« Reply #13 on: July 15, 2010, 06:49:40 AM »
Believe it or not, but this piece has the same frontal area as the stock unit. I hear you about a bigger cooler though. Good luck.
greenohawk69
« Reply #14 on: July 15, 2010, 07:24:24 AM »
What about Jegg's or Summit Racing?  Gotham Cycles?
"An enlightened people, and an energetic public opinion... will control and enchain the aristocratic spirit of the government." --Thomas Jefferson to Chevalier de Ouis, 1814
There are 4 boxes to be used in the defense of liberty:  Soap, Ballot, Jury and Ammo.  Please use in this order.  -- Ed Howdershelt
Pages: [1] 2   Go Up
