Stupid Question: How do you take the clutch hose off the master cylinder?
Started by Sleeptraffic, July 18, 2010, 10:15:42 AM
Sleeptraffic
-I thought with a 12mm wrench and turning counter-clockwise but the bolt will not budge.
-I came in from the garage to ask you guys, since if I stayed I would have probably stripped it by now.
-I know it's ridiculous but here's a picture of what I'm talking about. Any help/criticism of my intelligence is appreciated. Bike is an '00 M750 with coffin case reservoirs. Thanks!
scduc
I know for fact, that they are "gorrila" torqued from the factory.  Just make sure you've got a tight wrench on it 12mm isn't always 12mm. It will eventually budge, and when you are done, you will most likey want to get a new bolt/banjo. Your local dealer should stock these.
Very tight. Try tapping carefully from various sides with a tool.
Mine was like glued on, but when it came loose it was very sudden - so, I think they are often seized.
Apply heat maybe?
Sleeptraffic
Thanks for the suggestions guys. Nice to know I'm not the only one!  [thumbsup]
The Bearded Duc
Just serviced my brakes yesterday. They are on extremely tight, it helps if you still have the master on the bars. Gives you a little more leverage.
2001 M750 - Sold
64duc
Quote from: scduc on July 18, 2010, 11:11:18 AM
[/quote
Local auto parts house has 'em cheaper.
94 M900, 64 Diana 250
