Can Someone please tell me what this is and function?
Started by ducamonsta, July 19, 2010, 04:46:37 PM
ducamonsta
I have the asv levers, and by taking a look at the at the clutch lever there is this connector pin that the original oem lever made contact with every time its was pulled, now it just floating since I have the ASV lever, Is supposed to stay like that? what is function? ???
Pics taken with New DRIOD X :)  [thumbsup]
05 DUCA S2R800 yellow stock! ASV levers, Marvin Dual Exhaust, Harris Performance Grips, T-rex Sliders. Rizoma Conical bar, SSR Brake/Clutch cnc covers. Tammer G2 throttle tube.
KrakHor9
2003 Ducati Monster 620ie
Clutch safety switch.  The ecu will kill the engine if the clutch isn't in (switch contacts made, or plunger in the 'IN' position) and the sidestand is down.  With the switch removed, the ecu 'thinks' that the clutch is always pulled in.  It has no other effect on the system.
Some Suzuki's ecu's have a built-in part of the program that limits ignition timing and fuel delivery if the clutch is pulled in in an attempt to raise MPG and lower emissions.  To my knowledge, Ducati's efi systems do not do this.
ducamonsta
It does serve a function, but if you're careful about pulling the clutch in when starting and NOT trusting the 'N' neutral light then don't worry about it.
ooo that gives me an idea.
a toggle switch in a hidden place using the clutch switch wiring.
gotta toggle it to start. at least when not in neutral
but it would have to be a momentary type switch... somthing that resets itself...
vossy
"Life's short" "Ride More"
Mr.Saturn
My ASV levers have an arm that will depress the clutch switch.  It appears to be missing from yours; did you buy used?  You may have gotten an older model.  I'll go snap a pic or two so you can see the difference.
Mr.Saturn
Upon closer inspection of your pictures, you have the hole tapped for the toggle switch bracket.  The bracket is missing however.  Might wanna call ASV and see if they can send you one.
