February 11, 2025, 09:34:09 AM
OZ monsters
Running, Running.... Dead....
Topic: Running, Running.... Dead.... (Read 1899 times)
Monstar_100
July 20, 2010, 02:32:14 AM »
Well after riding up the putty and back today, I was slowly going into the garage... Then bike turns off...
No power at all... Turn the key from the off position to on... There is nothing... No trick little sweep of the dials...
Pulled the seat off and the tank up and notice the battery was steaming!!! Did a quick fuse check nothing...
Will have a better look in the morning...
Any suggestions?
Last Edit: July 20, 2010, 02:33:49 AM by Monstar_100
620ie Monster
suzyj
Does my bum look big on this?
Re: Running, Running.... Dead....
July 20, 2010, 11:02:15 AM »
Also check the 30A fuse on the other side of the battery box, near the relays.
Sounds like your battery was shorted out. Given that no fuses blew, it's most likely in the line down to the solenoid and starter motor, which is unfused.
If your battery was boiling, you should take it off the bike, as it can spill electrolyte on your bike or even catch fire. You'll almost definitely need a new battery.
888906
July 20, 2010, 11:52:53 AM »
Possibly a regulator/rectifier problem, with the battery being overcharged or "cooked" - when you fit the new battery, I suggest check the charging rate at the same time.
Desmo Clinic - Ducati Service Centre
ozducati
Carbon Imports & Accessories
July 20, 2010, 01:27:21 PM »
Quote from: 888906 on July 20, 2010, 11:52:53 AM
+1, sounds like a regulator cooked your battery... would be looking for a new regulator before you hook the battery again if i was you
PROUDLY SUPPORTING AUSTRALIAN RACERS & MOTORCYCLISTS
Monstar_100
July 20, 2010, 02:26:52 PM »
This was the first big ride with the new battery put in after the first battery I bought leaked all over the guts of my bike...
If I have to buy another that's the 3rd this fortnight
620ie Monster
ozducati
July 20, 2010, 02:59:55 PM »
did you check the regulator before the new battery ?? sounds like the other one cooked as well....i'd get it checked out before just putting another new battery in, there is a problem either with the regulator or alternator...
Quote from: Monstar_100 on July 20, 2010, 02:26:52 PM
Monstar_100
July 20, 2010, 03:12:55 PM »
The first new battery this fortnight was a motobatt battery and it leaked everywhere through a breather hole in the top of the battery before the bike was started so i went and got a yuasa battery and it was working a charm till yesterday...
no I have not checked the regulator or altinator yet...
Thank you for your help so far guys.
620ie Monster
Monstar_100
July 20, 2010, 04:16:21 PM »
How do i check the regulator?
620ie Monster
J5
I'm here to fix zee fridge
July 20, 2010, 04:59:21 PM »
Quote from: Monstar_100 on July 20, 2010, 04:16:21 PM
grab a multimeter and head here
http://electrosport.com/technical-resources/diagnosis-center/fault-finding-guide
Monstar_100
July 20, 2010, 11:24:50 PM »
^^^ thanks for that buddy...
To add to that plan, I'm getting a new battery in the morning and trying that, if it starts properly putting the multi meter to see if the battery is getting over charged...
Here's hoping I don't need a new regulator as it will cost $198 or one from flee bay at $145 second or third hand...
620ie Monster
J5
July 21, 2010, 12:03:09 AM »
if you need another , try and find a R1/R6 one
nice and large and when did you ever hear about one going bad ??
