February 06, 2025, 07:16:26 PM *
Author Topic: Is swapping gauges possible?  (Read 2171 times)
xskiervh
« on: July 21, 2010, 09:26:23 PM »
Is it possible to put a 1098 gauge/speedometer on a m696? What, how, or why wouldn't this work, besides mounting obviously?
« Reply #1 on: July 22, 2010, 10:04:39 AM »
from what i know... you would need
1098 motor, wiring, ecu
lofty55
« Reply #2 on: July 22, 2010, 04:42:26 PM »
Disable the immobilizer in the ECU. Then use any gauge cluster you want. At least I think that's right.
This is more fun than standing still at a radiohead concert.
'07 S2R1K
'02 998
« Reply #3 on: July 22, 2010, 06:59:54 PM »
no one can disable the 696 ecu's yet. well unless you can find a rexxer equiped shop. supposedly that system can modify the computer. but then you have the wiring issue. the gauges use different connectors. and i'm sure there are tons of other details that have to be hashed out.
lofty55
« Reply #4 on: July 22, 2010, 07:41:29 PM »
Good to know raux, thanks
'07 S2R1K
'02 998
xskiervh
« Reply #5 on: July 22, 2010, 09:15:04 PM »
Ok cool, thanks for the replies Smiley was just curious how easy or hard that may be, probably beyond my mechanical or electrical skills based on those answers.
Rameses
*Your Mom* has a Hypermotard
« Reply #6 on: July 24, 2010, 09:12:58 PM »
The easiest way to do it would probably be to tear your stock cluster apart and then hide the immobilizer somewhere.
Then take whatever cluster you want to use and wire up the necessary sensors to it.
I'm sure that's a hell of a lot easier said than done though.
ducmon695
« Reply #7 on: September 10, 2010, 06:06:19 AM »
Is it possible to switch older clusters?  Like I have a 07' 695 and I wanted to get the clutster from like the S4R that has the white strips on the gauges.  Or is it possible to change to an older superbike cluster, like pre 1098?
2002 Desmohio/Cycle Cat 900ss Cafe
