Finnicky case savers
Started by Airborne, July 25, 2010, 07:52:19 AM
Airborne
Apparently these things are hit or miss in terms of fit. Has anyone took a grinder to theirs to thin out the metal so it doesnt rub the chain? This would kind of defeat the purpose but would be better than nothing i guess.
2007 Monster S2R, Vespa GTS 300, 23 Triumph Tiger 900 Rally Pro, Vino 125
DarkStaR
If you have a 15T front sprocket (Like me) it may rub a little.  You can try to bend it in the right areas to make it fit better.  Mine use to rub just a little bit, but I think the chain did the work on it's own, thinning out the area.
Make sure you have the right one... there are 2 of them. DS1000 and non DS1000.
aside from that, ive had 2 of them, one in a 900 and another on my DS1k, they both fit spot on with a 15T.
Airborne
Yeah at first I thought I had the wrong one, but ca-cycleworks explained it to me. It is the right model, just fits tight. I guess i'll mess with it.
Also heman, I used the mikes xs chain presser and riveter...it worked ok until it broke.  [bang] I can probably fix it though. If you buy a chain tool buy the $100 one and don't look back.
erkishhorde
Yup, really tight fit. After you get in on the first time it'll wear out a bit from the chain and be just fine.  :P
Quote from: Airborne on July 25, 2010, 08:34:01 AM
How did it break? i know 3 guys who own them and it works great. Ive used it on 2 chains, and they've used it on countless other chains too.  If you snapped the pin, then your using it wrong and its just an $8 mistake.
Airborne
yeah i snapped the riveter pin. i was able to finish riveting with the broken part anyway. They sell just that part?
Goggles Pizano
Mine is tight, bought for a 620 w/14t it was fine.  Running on a 900 w/15t it rubs, seems to have clearanced itself.  I'm not concerned about it.
Quote from: Airborne on July 25, 2010, 04:07:37 PM
Yea, the pin is replaceable, they snap if you apply to much force when the pin isnt set perfectly. This happens with the $100 did tool too.
Part #35-0007 on mikexs.
vossy
I've got a case saver on my S2R1k with a 15t front sprocket and fit fine.
"Life's short" "Ride More"
