January 04, 2025, 11:24:09 PM *
Pages: [1] 2   Go Down
Author Topic: which brakes do I have? PICS included  (Read 3826 times)
spaugh
« on: June 05, 2008, 08:24:19 PM »
I've got full floaters on my s2r 800 dark that the PO had installed.  I have a broken brake lever that I need replaced and I don't know what part I need since its not stock.  At least I don't think its stock.  Can you guys let me know what I've got?  BTW, my brakes work great.
S2daRk
« Reply #1 on: June 05, 2008, 08:56:04 PM »
Looks like a radial master from 749/999.
« Reply #2 on: June 05, 2008, 10:01:13 PM »
coffins from multistroodle?
SBKnhas round pee cups dont it?
« Reply #3 on: June 05, 2008, 11:41:33 PM »
Older SBK have the round separate reservoirs.
That does indeed look like a 749/999 radial master.
BTW, I think those rotors are a bit rare and worth some money.
teddy037.2
« Reply #4 on: June 06, 2008, 12:30:34 AM »
+1 on the 749/999 radial MC
those calipers are the fancy ones as well...
I am SO jealous right now  Undecided
Omnipotent Potentate
Personal Pretext
« Reply #5 on: June 06, 2008, 02:55:32 AM »
What's special about those calipers?  To me they look like normal 40mm mount 2-pad 4 piston calipers.
And +1 one more for the 749/999 radial masters.
But yeah, none of that break set up is stock
« Reply #6 on: June 06, 2008, 04:19:14 AM »
+1
The calipers are the old single pin variety.
spaugh
« Reply #7 on: June 06, 2008, 10:29:14 AM »
sounds like I scored on the brakes, only thing is they are a little twitchy.  If I lay on them to hard too fast, the front end locks up fairly easily.
Personal Pretext
« Reply #8 on: June 06, 2008, 11:09:04 AM »
Those are 'finesse' brakes  Wink
Without knowing what sort of pads are in there, I'm just guessing here - but a less aggressive pad might be more to your liking.  The former owner might have something like sintered pads that have a lot of initial bite
teddy037.2
« Reply #9 on: June 06, 2008, 01:14:16 PM »
+1
tequila goggles had me thinking they were the 999 calipers... that's why my sig is what it is!  laughingdp drink
Spike
« Reply #10 on: June 06, 2008, 02:50:04 PM »
I have the same cast iron rotors on my bike and I am runnnig Ferodo Platinum organic pads as opposed to the sintered pads. I get more feel and the organic pad will help the rotor last longer. My .02 cents. Smiley
« Last Edit: June 06, 2008, 02:53:56 PM by Spike » Logged
« Reply #11 on: June 06, 2008, 02:53:36 PM »
I ran Ferodo Platinums on my iron discs with basically the same calipers.
Moderate initial bite, but plenty of power.
Personal Pretext
« Reply #12 on: June 06, 2008, 06:09:21 PM »
Have another  waytogo  The 65mm to 40mm adapters should have made you look twice.. but if you had the T-googles on then you might have just seen 4 calipers.
teddy037.2
« Reply #13 on: June 06, 2008, 07:33:39 PM »
 laughingdp
mdriver
« Reply #14 on: June 07, 2008, 01:11:45 AM »
What bike are those rotors off of?
Bike Info: 2001 Ducati M750 Dark, 2007 Triumph Bonneville
Pages: [1] 2   Go Up
