February 15, 2025, 01:06:54 AM *
Pages: 1 2 3 [4]   Go Down
Author Topic: Superquadrata  (Read 18442 times)
« Reply #45 on: February 02, 2011, 01:09:09 PM »
How is it a branching out of their engine design? It's just the latest iteration of the current SBK motor which will now be tilted rearward in the frame a little. Still a water-cooled, 4 valve, 1200cc, 90* twin, with desmo valves though. Granted, gears instead of belts. Am I missing something else?  Huh?
The chassis seems to be the big leap forward.
It is branching out somewhat -- from the top, you can practically confuse a 1985 Pantah case and a Testrastretta case from a distance (I mean just the case halves together) -- same basic 11 deg vertical and 79 deg horizontal -- which is shared by all 2v and 4v engines.  even the supermono...
even moving the jugs somewhat is a big step given this design persistence.
« Reply #46 on: February 02, 2011, 01:12:34 PM »
yeah gotta go with the leap forward on this one,
cassette type gears, different V layout not just the motor tilted, cam gear drive, i bet the internals are going to be a lot different as well with the huge oversquare ratio.
ok it's a 90 deg twin with desmo valves...
everything else will be new.
« Last Edit: February 02, 2011, 01:14:17 PM by Raux » Logged
duccarlos
« Reply #47 on: February 02, 2011, 02:23:03 PM »
I heard that a small group of people saw an early version of it. They were impressed with what little they saw.
LA
The Sleek Black Beauty
« Reply #48 on: February 03, 2011, 06:45:02 PM »
its going to make an 1198 look inexpensive, price-wise.
It is "inexpensive". Yes I put quotes around it (I can't afford one), but the 1198 SP is better and cheaper than last years 1198 S model.
LA
Pages: 1 2 3 [4]   Go Up
